Check Engine Light
Old Sep 8, 2007 | 07:24 PM
BLEW's Avatar
Default Check Engine Light
Greetings,
I'm a new member to the Forum. I have a 2005 Chrysler XFire Roadster with approx. 15,000. The other day the Check Engine Light displayed. I took the car to AutoZone to get a readout which was P2098. Does anyone have an idea what this means. Any help would be most appreciated...Thanks!!!
Old Sep 8, 2007 | 07:40 PM
Default Re: Check Engine Light
First of all WELCOME TO THE FORUM.
I am sure someone in here will be able to answer your question. This forum is a great source of information about all models of the Crossfire. Enjoy your new car and best of luck to you.
Old Sep 8, 2007 | 11:23 PM
jimbos's Avatar
check your gas cap, make sure its tight.
Old Sep 9, 2007 | 03:42 AM
CrossfireLTD's Avatar
Cool Re: Check Engine Light
Congrats and Welcome to the Forum!!!
Are you sure that the code is P2098?
Old Sep 9, 2007 | 09:52 AM
Gwetoe's Avatar
It might be the "710" fluid.
Old Sep 9, 2007 | 12:24 PM
danimal's Avatar
Originally Posted by BLEW
Greetings,
BLEW, It appears to be related to 'fuel trim'...whatever that means. Make sure that the gas cap is tight because it will definitely throw a code if not. If the cap is tight, the code clear, and it doesn't reappear...don't worry about it.
Old Sep 9, 2007 | 12:25 PM
danimal's Avatar
Angry Re: Check Engine Light
Hopefully you will get just as good advise when you need it!!!
Old Sep 9, 2007 | 01:11 PM
It is definitely a "powertrain" code, but I could not find that code number under Chrysler or Mercedes Benz.
Go here for Dodge/Chrysler/Jeep Codes, and you may want to post your question here also and see if you can get an answer.
http://www.obd-codes.com/trouble_codes/dodge/
Go here for Mercedes Benz Codes.
http://www.whnet.com/4x4/dtc.html
Old Sep 9, 2009 | 03:29 PM
Osofast2's Avatar
Hello All ! my CRossfire has been doing the same thing , Work on one Sat. Un plug all O2 sen.and clean the plugs out , cleaned the mass air sensor , and did not give a code for about two weeks ,But it back now . will take it in a week or so , but before i do i;m going to change out the o2 on bank 2 and see what happen ! got o2 off ebay for 60.00 Will let you know what happen.
Old Nov 5, 2009 | 11:39 AM
N2UK's Avatar
Hi Everyone!
I have been a lurking member for a while.
I just pulled the code for my check engine light this morning. I bought a V-Checker off Ebay and it arrived last night. I received the same code P2098 "Post Catalyst Fuel Trim System Too Lean". I set the device to Professor mode and then set it to Benz.
Osofast2 - I live in Lexington as well. The signal came on twice in the last month. It disappeared the first time. The second time it came on after I filled up with premium gas after a tankfull of regular my wife accidently pumped a few days before. I think its the gas, but I don't know what to replace or rest.
Old Nov 5, 2009 | 12:57 PM
With a bit of luck it will go away again, press the clear codes button and keep your fingers crossed. the gas will probably not do that as others have used regular and had no problems (yet?)
My second bit of advice is to just drive it yourself.
Old Nov 5, 2009 | 01:01 PM
N2UK's Avatar
We are probably getting some crappy gas in the area, so I would say it might not come back. Thanks for the response.
Old Nov 5, 2009 | 03:15 PM
Originally Posted by N2UK
Hi Everyone!
Ken, is that you?
Old Nov 5, 2009 | 03:56 PM
N2UK's Avatar
Ken, is that you?
No. My name is Tom. My wife and I have a 2005 Aeroblue Limited Roadster in Lexington with University of Kentucky tags N2UK. We bought the car in June with 19,000 miles on it and have had a blast. I'm a little embaressed to say we hit 30,000 last week.
Old Nov 5, 2009 | 04:19 PM
N2UK is the call sign of a Ham Operator in New Jersey.
I wondered if he'd moved without yet filing with the FCC, and if we had yet ANOTHER ham operator on here.
WOW! I have put almost 5,000 on mine since July 6th - and I thought I'd gone nuts!
Old Nov 5, 2009 | 10:40 PM
Let's hope you are not an English prof or you would be embarrassed.
Sorry, slow night.
Old Nov 6, 2009 | 09:54 AM
N2UK's Avatar
Maybe the ham operator is a UK fan also.
Old May 10, 2011 | 02:46 PM
silverfish1's Avatar
Banned
P2098 Post Catalyst Fuel
Basically the guy is saying good luck to all the problems you are going to have with the worst car ever made.
Buy Jap cars they last longer and have better engine-
Old Jul 10, 2011 | 08:22 AM
jayedbuffie's Avatar
mine does it often, push down on cap when tightening. also the plunger afair must be out before door is closed so the door pressure will close it.
Old Jul 10, 2011 | 08:41 AM
Caught in a Xfire's Avatar
not a fan i take it and i think your forgetting the Edsel
