New roadster top and new wing
Old Mar 25, 2008 | 02:31 PM
RMADERMAN's Avatar
Default New roadster top and new wing
Last month the dealer replaced Ashley's roadster top under warranty. Today I noticed mine was starting to separate at the lower right corner. Hers had separated on the lower left corner. They are ordering a new top for mine and when it comes in they will be replacing the top as well as the spoiler because it is cracking where the wing attaches to the pillers that go into the trunk.
Old Mar 25, 2008 | 02:40 PM
Iamfink2's Avatar
Default Re: New roadster top and new wing
Randy are you talking about coming apart from the rear window and also are you still under the original warranty or extended warranty?
Old Mar 25, 2008 | 03:20 PM
RMADERMAN's Avatar
Yes, the window is separating from the canvas. And yes they are still under factory warranty. Ashley's factory warranty expires April 8.
Old Apr 7, 2008 | 06:06 PM
blacklimitedcoupe's Avatar
Hi Randy,
Which dealer do you use? I'm trying to find a reputable dealer in our area to take mine to for warranty issues. Any help would be appreciated. Thanks!
Old Apr 7, 2008 | 08:00 PM
RMADERMAN's Avatar
Originally Posted by blacklimitedcoupe
Hi Randy,
I use Tamiami Chrysler in Miami. Because I have been there so frequently the past couple of months, I am on a first name basis with everyone from the guys who bring and take the XF in for repairs to the head of service to the Enterprise rental personnel. I keep asking them when is payday. They know both SRT's intimately. They smile and shake their heads when I drive into the dealer
They finally gave me Ashley's wing unpainted. They wouldn't paint it due to the fact that the color was changed. They wanted the old one before they gave me the new one...... They finally relented and gave it to me. What was I going to due with the cracked one? Fix it and sell it on Ebay. Today it was painted. Tomorrow the wing will get another coat of braze red. I dropped her SRT today to remove the old cracked wing, replace the struts (hopefully) replace the valve cover gaskets (slightly leaking)
I purchased my SRT from Punta Gorda Chrysler, but I really have minimal experience with their service department. Tamiami really does not have a truely competent or certified tech for XF's. Bur the head guy will listen if you can get to him and his assistant is a good guy.I think I have probably educated them as much as anyone with the forum's very knowledgable members. ie IC pump.
Good luck. Let me know where you go. If you know what the problem is, I think most dealers will follow you lead. If they don't look for a different dealer. Try and see if you can talk to the head of service. Pick his brain.
Old Apr 7, 2008 | 08:06 PM
Voyager's Avatar
sorry im a noob at this so what kind of symptoms do you get from a slightly leaking valve cover gasket?
Old Apr 7, 2008 | 08:42 PM
RMADERMAN's Avatar
The engine bay in both SRT's are kept as clean as the exteriors. (at least where my hand will reach) There was some build-up of oil/dirty grease around the base where the valve cover gasket is located.
If you take off the engine cover it will be obvious.
Old Apr 8, 2008 | 08:28 AM
RIOT's Avatar
Would love to have one of those cracked wings to hang in my Garage.
Right next to the dented Jack Daniels hood.
PNA
Nov 12, 2020 04:44 PM
Hoppy
Dec 7, 2018 07:36 AM
PimpDaddy
Sep 29, 2016 11:55 PM
Trenzman
Jul 24, 2015 10:12 PM
mike28117
Jul 17, 2015 01:59 PM
