OK...found new feature
Old Oct 2, 2008 | 06:46 PM
woodlands1's Avatar
Default OK...found new feature
Am I the only person on this forum that didn't know that when you use the lock button on the remote the doors and truck lock...and, so does the center console glove box?
I didn't realize that the console glove box even had a lock. But, today while in the car, I hit the lock on the remote (while in the car with the key in the ignition) and locked the doors. Then, while driving I tried to open the console glove box, but it was "stuck" shut. I about broke the cover trying to pry the lid up to get in. I thought that somehow, the glove box door was jammed. Then, I thought surely not...I hit the open on the remote and sure enough the glove box opened normally. It was locked and then unlocked.
Maybe I ought to read the instruction manual?
Old Oct 2, 2008 | 07:03 PM
itsky's Avatar
Default Re: OK...found new feature
Also the gas cap will lock as well.
Old Oct 2, 2008 | 07:14 PM
Erzer's Avatar
I won't say you are, but you might be in the minority. Did you also know that if the glove box is unlocked and the car is locked, the alarm will sound?
Old Oct 2, 2008 | 07:16 PM
robby363's Avatar
The center console glove box only locks on the Roadster the Coupe doesn't have that feature.
Old Oct 2, 2008 | 08:25 PM
Mr. Max's Avatar
Thumbs up Re: OK...found new feature
Great, I won't waste my time locking it anymore. Good work!
Old Oct 2, 2008 | 08:34 PM
GB'sXFire's Avatar
I noticed that the center console would lock when the top was down. Everytime I would need my wallet or cell phone, the darn center console was locked when the top was down. I believe this lock is controlled by air, or lack of air, (suction), (yellow hose under console). When I swapped my cup holder out for the storage bin, I noticed this hose coming up from the rear of the tunnel running to underneath the center console to something that looked like the locking mechinism. I disconnected the fittings that connect the hoses together to remove the console for the swap, but when I put everything back together, I noticed my center console would not lock, so Iam thinking maybe there is a leak now in the fitting causing the center console not to lock when the top is down, which I don't miss. I would fix it so it stays locked with the top down, but only if I could override this feature so I could open the console when the top is down. Maybe I'm wrong, so please correct me if I am . Thanks.
Old Oct 2, 2008 | 08:42 PM
GB'sXFire's Avatar
OK, never mind. I just ran out to the car, got in, locked the doors with the remote and the center console was locked. Duh!
Old Oct 3, 2008 | 03:02 AM
Erzer's Avatar
Don't know for sure, but is it a difference between completely unlocking the car vs. just the drivers side? I've got an 07 and have never had a problem with being able to get into the console when driving...but I almost always unlock both doors. Just a thought.
Old Oct 3, 2008 | 03:16 AM
apkano's Avatar
Life is random...so am I.
Groundbreaking! Next thing you guys are going to try to tell me is that the cruise control stays engaged even if you are shifting gears in the 6speed!
Old Oct 3, 2008 | 03:47 AM
popeye's Avatar
When I reach about 15 miles an hour the doors lock. But I have no trouble getting into the storage compartment in the console...
Old Oct 3, 2008 | 07:05 AM
I can open my console while driving. It only locks when you lock the car with the remote. The door lock automaticly when you are driving but the console does not with the top up or down. When you lock the car with the remote, it locks the doors, console and gas .
Old Oct 3, 2008 | 07:21 AM
ShirazRoadster's Avatar
I wish it would lock the glovebox as well. I inevitably need a CD or something when I manually lock it when I leave the top down and forget to unlock it when I start the car. Hard to open with no key
Old Oct 3, 2008 | 07:29 AM
blackberry's Avatar
Also if you don't get the trunk closed the dome lights will stay on.
Old Oct 3, 2008 | 07:51 AM
Roadsters have a trunk?
Old Oct 3, 2008 | 08:31 AM
AlG's Avatar
AlG
Heck, even with the top down I can put at least twice as much stuff in as those guys who have a Solstice/Sky
Old Oct 3, 2008 | 11:51 AM
Mr. Max's Avatar
Damn, I thought he WAS talkin' about the glovebox as well as the console bin.
Old Oct 3, 2008 | 05:23 PM
woodlands1's Avatar
My doors never lock, unless I lock them.
Old Oct 13, 2008 | 06:13 PM
markr6754's Avatar
There are many options you can set with the keyfob remote. Auto lock is one of them.
Old Oct 14, 2008 | 04:27 AM
REVIT93RX7's Avatar
The Solstice/Sky has almost no trunk space. Open the trunk? If you can call it that. You have enough space for a brief case.
Old Oct 14, 2008 | 06:26 AM
MikeR's Avatar
If you read the manual you will get a 'man rule' violation ticket!
MikeR
