How to tell Limited ed from standard
Old Nov 22, 2008 | 04:11 AM
hooshcrossfire's Avatar
Default How to tell Limited ed from standard
What are the tale tale signs?
Old Nov 22, 2008 | 04:54 AM
Default Re: How to tell Limited ed from standard
A quick glance difference on the outside are; the base only comes in black, no silver trim, and cloth seats, and no fog lights.
Here's a list of differences; Do a search and you can find a number of threads with more discussion.
-No Cupholder
-No Homelink
-No "Crossfire" nameplated stainless steel door sill plates
-No storage net between both front seats
-No storage nets behind both front seats mounted on the bulkhead at the bottom
-No silver cigarette lighter
-No Tire Pressure Monitor
-No Aluminum rubber studded pedals
-No Power Seats
-Different seats altogether with adjustable headrests
-No Leather Seats
-No Heated Seats
-No 6 speaker 240 watt Infinity Modulus radio (Base just has a 4 speaker stereo with black ***** and NO AMPLIFIER)
-No Fog Lights
-No Silver trimmed speaker grilles
-No Satin Silver Finish exterior windshield frame, side fender vents and door handles (all black on Base)
-No Chrome finish on exhaust pipe tips
-No Automatic Transmission Option
-No Color Option other than BLACK CLEARCOAT
-No Interior Color Option other than BLACK CLOTH
-No Gas Strut on Glovebox door (This Strut Available on the Limited creates a slow opening door rather than just dropping open)
-No Heated Exterior Mirrors
-No Cabin Air Filtration System (Base just has a simple recirculation feature)
-And usually comes standard with the All Season Performance Conti's
-No Floormats
-No Touring Gear
Old Nov 22, 2008 | 06:17 AM
ok lol thanks for that i bought a 05 crossfire in black roadster yesterday was just making sure.. it came with all of that and sat nav too!
not sure if i have tyre pressure monitor tho.. but cheers!
loving the car...
Old Nov 22, 2008 | 06:19 AM
If you have the Limited, you have the TPS. It's standard.
Old Nov 22, 2008 | 06:30 AM
its on the stereo right?
Old Nov 22, 2008 | 06:35 AM
It displays on the dash cluster when your tires are not inflated properly. If you turn your key to the on position, it should light up.
Old Nov 22, 2008 | 06:38 AM
Old Nov 22, 2008 | 06:40 AM
ahhh ok i get you thanks!
pitty there isnt a mpg so i can see what i can get...
But so far so good having trouble with the roof ... keeps beeping cant open it! managed once.. lol my TT was sooo much easier lol
Old Nov 22, 2008 | 07:20 AM
Bladecutter's Avatar
If it is beeping, then you need to check these couple of things:
* Make sure the trunk divider thing is in the up position, making the trunk as small as possible.
* Make sure the trunk is fully closed.
* Make sure you push the latch part of the roof up after turning the handle to unlatch it.
After that, it should open.
BC.
Old Nov 22, 2008 | 09:20 AM
BC.
Yes, make sure the divider is making good contact on the switch. You might have to jiggle it a little.
Old Nov 22, 2008 | 09:25 AM
maxcichon's Avatar
These things can be found in the owners amnual. If you don't have one, you can download it here:
http://www.chrysler.com/en/owners/manuals/index.html
The previous advise is good. If these things are in place. it should open. The cargo divider is a bit finicky! Pull to the rear and push up.
TerryR
Dec 13, 2019 03:27 PM
rmcdaniel12
Nov 4, 2015 04:08 PM
thatcham
Oct 5, 2015 02:41 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Calitony
Sep 24, 2015 12:53 PM
