What is the scedule b?
Old Jul 15, 2009 | 10:21 PM
plainfire's Avatar
Default What is the scedule b?
i really cant aford to bring my car so if you can please tell me what it is i'll do it myself thanks. i know schedule A is the oil change. last time the dealer soaked me for 170 bucks. thanks i read on here how to reset the counter. thanks
Nick
Old Jul 18, 2009 | 11:08 PM
Sonza's Avatar
Default Re: What is the scedule b?
SCOPE OF WORK FOR “B” SCHEDULE
MAINTENANCE SERVICE
Oil Change
² Change oil and replace filter
Maintenance
² Rotate tires
² Replace dust filter (if equipped)
² Lubricate hood hinges, latch, and secondary latch
² Reset FSS Display
Function Check
² Horn, hazard warning flashers, turn signals, and indicator
lamps
² Headlamps and exterior lighting
² Windshield wipers and washer system
² Check seat belts for damage and proper function
² Test hydraulic brakes and check parking brake function
Inspection
² Check front and rear brake pads for lining thickness
² Check condition of front and rear brake discs
² Check tires for damage and general condition
² Check tire inflation pressures and correct if necessary
² Check major underbody components for leakage or
damage (if there are signs of leakage, determine cause
and repair)
² Check condition of front axle ball joints and rubber
boots
² Check condition of steering components and rubber
boots
² Check underhood components for leakage or damage
(if there are signs of leakage determine cause and
repair)
² Check condition of accessory drive belt
² Check headlamp aiming, adjust if necessary
² Check windshield wiper blades, replace if necessary
Fluid Levels
Check fluid levels for the following systems and correct if
necessary. Should there be a loss of fluid that cannot be
explained by regular use, trace and eliminate the cause.
² Engine cooling system (check corrosion inhibitor/
antifreeze)
² Hydraulic brake system
² Power steering system
² Windshield washer system
That should keep you busy!
Old Jul 18, 2009 | 11:46 PM
plainfire's Avatar
Thanks very much for the info. Most places now check lights and fluids while doing a oil change
but not brakes. Acutally last time the dealer let me leave with a burnt out headlight.
WesMichaels
Aug 2, 2004 04:50 AM
