Multifunction tool
Old Dec 19, 2009 | 11:56 PM
Donny's Avatar
Default Multifunction tool
Looking for a multifunction tool, anyone have an extra?? Or where can I get one??
Old Dec 19, 2009 | 11:58 PM
GDC-SRT's Avatar
Default Re: Multifunction tool
Have you checked the little pouch behind the seats?
Old Dec 20, 2009 | 10:27 AM
wbaker1970's Avatar
did you check in the trunk under the carpet, Bought my 05 roadster and couldnt find it either someone put it where the wonderful
spare tire is , dont know why they would store it there .
good luck
Old Dec 20, 2009 | 10:34 AM
Donny's Avatar
Have checked the car from front to back, top to bottom with no tool in site.
Old Dec 20, 2009 | 10:37 AM
GDC-SRT's Avatar
There is some info on this link, including part number and price OUCH!
https://www.crossfireforum.org/forum...pose-tool.html
Old Dec 20, 2009 | 11:09 AM
texas t's Avatar
Talking Re: Multifunction tool
Sounds Like, what what i have been called before
Old Dec 20, 2009 | 12:49 PM
Donny's Avatar
Thanks may have to bite the bullet and buy one from a dealer??
Old Dec 20, 2009 | 12:53 PM
70GT6's Avatar
Over $100 (almost $200 at some) from the dealer.
EBAY as usual.....
Old Dec 20, 2009 | 12:56 PM
MikeR's Avatar
Why? I havent found anything that you really need it for. That is probably why everyone finds them still in the wrapper, stuffed out of the way somewhere.
Old Dec 20, 2009 | 12:57 PM
70GT6's Avatar
Me either..but if you want one the dealer is not the way to get it.
Old Dec 20, 2009 | 01:18 PM
Donny's Avatar
Can you manually close or open top with out the tool?? When it comes to mechanical stuff I am an idiot!!
Old Dec 20, 2009 | 01:21 PM
MikeR's Avatar
Open the top??? Maybe with a big can opener.....
Oh, you must have one of those that they ran out of roofs for and use cloth.... The roadster guys will have to answer that one...(but I would guess you could)
Old Dec 20, 2009 | 01:28 PM
GDC-SRT's Avatar
I have never used mine.
Though you can lower the top with it.
Ebay is the way to go.
Old Dec 20, 2009 | 09:57 PM
Sandgrounder's Avatar
if it was an import from the States,it was removed along with the inflation system and anything elsethat wasnt attached ! import rules .
180 had a couple of the tools and I am sure if I can get one, a local machine shop can produce them for far less than Chrysler cost
Old Dec 21, 2009 | 07:52 AM
hcarter's Avatar
I raise and lower mine all the time (manually) as i am waiting on sensors from the dealer If you dont have a tool (YOU AINT MOVING THE TOP) the dealers can get them 149.00 but it would be better to have one made out of a old (long 12 inch) medum screwdriver ......the open end wrench has to be fairly thin to fit in the gap at the toneu cover.....not sure the size as my car is at home in the garage and i'm at work but i'm sure someone can give you the measurements ......Good luck
Howard.
Old Dec 21, 2009 | 09:14 AM
I had two and I gave one away, however I do have a drawing I made of one. If anyone wants to pm me with their email address I will send them a copy. There appears to be two types of these tools, I have posted a picture somewhere of the two kinds.
The one I have drawn comes from a coupe, they are identical except for the angle of the offset at the end, the one I have drawn is 40 degrees, the other is less. The opening at the end is 10mm (.397") I do not know if the type used matters at all, the other one I had was the type that had a less pronounced offset and it may have come from a roadster.
Old Dec 21, 2009 | 10:46 AM
Hawk Monster's Avatar
Two types of tools that is interesting. I took the one out of my coupe and it was 10mm spanner with a part number of A 193 899 03/80.
Would someone please look at their roadster and see the part number on their tool. Perhaps we can add this to our list of parts.
I used my tool when I had to have the car towed and needed to get to the front tow ring. I did not have a flat blade screwdriver in the car.
Old Dec 21, 2009 | 11:14 AM
hcarter's Avatar
PM SENT ! YOU
edit: here it is off my roadster's: A 193 899 03 80
Old Dec 21, 2009 | 11:16 AM
hcarter's Avatar
I'll send you a pm . with a email address ,,,thanks
