Multifunction tool
Old Dec 21, 2009 | 11:22 AM
hcarter's Avatar
Default Re: Multifunction tool
You also need a allen wernch a number 6 if I recall right ))))to unlock back window if the top is up and your trying to get it down...
Old Dec 21, 2009 | 11:39 AM
KJN's Avatar
KJN
Hi,
I used the link sent you for ebay, went to the store listed and purchased one for 28 dollars with shipping.
Check it out...
Old Dec 21, 2009 | 11:43 AM
Hawk Monster's Avatar
Interesting two different part numbers. The first number is different. I guess we found another difference between roadster and coupe.
I double check my tool from the coupe says 193 as the first three numbers.
Old Dec 21, 2009 | 01:50 PM
I misread mine. It's really hard to make out the numbers. Mine is 193 also.
Old Dec 21, 2009 | 02:01 PM
Donny's Avatar
I had two and I gave one away, however I do have a drawing I made of one. If anyone wants to pm me with their email address I will send them a copy. There appears to be two types of these tools, I have posted a picture somewhere of the two kinds.
The one I have drawn comes from a coupe, they are identical except for the angle of the offset at the end, the one I have drawn is 40 degrees, the other is less. The opening at the end is 10mm (.397") I do not know if the type used matters at all, the other one I had was the type that had a less pronounced offset and it may have come from a roadster.
pm my email .....THANKS
Old Dec 21, 2009 | 03:35 PM
Two types of tools that is interesting. I took the one out of my coupe and it was 10mm spanner with a part number of A 193 899 03/80.
Would someone please look at their roadster and see the part number on their tool. Perhaps we can add this to our list of parts.
I used my tool when I had to have the car towed and needed to get to the front tow ring. I did not have a flat blade screwdriver in the car.
From my 2004 Coupe, the one I have a drawing of.
A 193 899 02 80
Old Dec 21, 2009 | 07:57 PM
Looks like we still have 2 different part numbers for the tool.
A 193 899 03 80
A 193 899 02 80
Interesting. Corrected the Part number.
Old Dec 21, 2009 | 07:59 PM
hcarter's Avatar
A 193 899 03 80
A 103 899 02 80
Interesting.
one for coupe and one for roadster ,coupe
Old Dec 21, 2009 | 10:57 PM
Donny's Avatar
A 193 899 03 80
A 103 899 02 80
Interesting.
Wondering would either work for a roadster???
I
Old Dec 22, 2009 | 12:04 AM
I
Of course they will, the Coupe has no need for the wrench end as it's just for the roadster top.
Hawk Monster has the part numbers down wrong, they should be,
A 193 899 03 80
and
A 193 899 02 80 (shown in my drawing)
I would post a photo of each and the drawing if I could.
Old Dec 22, 2009 | 10:42 AM
Thanks onehundred80. Sorry for the typo.
Old Dec 22, 2009 | 02:06 PM
Well it took a while but I got to the bottom of it. There is only one part for both the roadster and coupe.
It is Chrysler part number 5140795AA. Retails for about $150.
There is a need for the part in BOTH cars. In the coupe, with an automatic you do need it or a very skinny screw driver if you have electrical (battery) problems. You use this tool to get it out of park. This is a problem if you need to have the car towed and have this issue. See your owners manual.
In the roadster, you need it for an automatic for the same reason as the coupe above and also to raise and lower the top manually. HCarter also was super in telling us you also need a 6 allen wrench. Hope this clears up the issue.
Old Dec 22, 2009 | 07:54 PM
The Chrysler part #5140795AA could be MB parts #A 193 899 03 80 or
#A 193 899 02 80
The tool is of use mostly in the roadster for use on the top.
The auto transmissions can be unlocked from the park position and the passenger side lower front grilles can be removed to access the towing hook using a slim screwdriver if the tool is not available.
syfi
Mar 28, 2026 04:14 PM
rampntlion
21
Feb 11, 2019 08:18 AM
smokey847
Nov 12, 2015 11:54 PM
81's
Sep 13, 2015 04:34 PM
MAXIMUM
Aug 4, 2015 11:04 PM
