Air Pump
Old Feb 24, 2010 | 11:57 AM
wheeldealer's Avatar
Unhappy Air Pump
Went down to the dealer yesterday due to check engine light popping on, come to find out that it was a bad air pump. The tech said it was going to be a 1k repair. " thank god for extended warrantys"
Has anyone on this forum experienced the same problem?
Old Feb 24, 2010 | 12:17 PM
AlG's Avatar
AlG
Default Re: Air Pump
Just wondering...how many miles on your car?
Old Feb 24, 2010 | 12:38 PM
Goldwing's Avatar
What air pump? Any details would be appreciated.
Old Feb 24, 2010 | 12:46 PM
aschrager's Avatar
Could be a bad relay control module. That is what causes the secondary air pump code to come on most of the time.
Old Feb 24, 2010 | 02:30 PM
05 roadster 26k on the clock
Old Feb 24, 2010 | 02:39 PM
tighed1's Avatar
Beat me to it.
If you are brave enough open the RCM and close the contacts on the relay marked "E" on the right in this photo.
The air pump should turn on. I noticed that the contacts on this particular relay in one of my RCMs is burnt pretty good. I sometimes get fault code PO445 (or is it 405, 455, 505?) If I recall correctly you don't even have to have the key in or on to do this.
If the pump operates I'd say it's good. If not I'd look the RCM over.
Old Feb 24, 2010 | 03:19 PM
I do recall the day that the check engine light went off, I turned off the ignition and the pump did keep on going,eventually it did shut off and then the check engine light went on that night
I had no idea that it would be that much $ to repair
Old Feb 24, 2010 | 03:36 PM
Punkin's Avatar
I have had an air pump go bad in my wifes SSB. I thought I would be able to get one from someone on the forum who was piecing out but so far no takers. The dealership will sell me a new one for 125.00. I was really suprised the cost was that reasonable. I will be replacing hers when the weather warms up. If you find a deal better than the dealership price, shoot me a PM.
Old Feb 24, 2010 | 03:51 PM
Question Re: Air Pump
1k is a sh** load of money, is it that complicated to fix
Old Mar 31, 2010 | 12:14 PM
Slims's Avatar
Mine is doing the same thing...made a decision that the 1300 CAD just wasnt worth it.
tritongreen
Sep 18, 2015 07:32 AM
RacerXofFL
Sep 15, 2015 05:00 PM
cppeabody
Sep 15, 2015 08:43 AM
81's
Sep 13, 2015 04:34 PM
crmnal
Sep 6, 2015 08:07 AM
