Removal of panel behind Roadster seats
Old Dec 29, 2010 | 10:08 AM
microndel's Avatar
Default Removal of panel behind Roadster seats
Does this panel come out? The one that contains the sub speakers. If so, what are the steps to take it out<
Old Dec 29, 2010 | 10:21 AM
Bigkid's Avatar
Default Re: Removal of panel behind Roadster seats
Don't want to mess with that one. That houses your gas tank. Welcome to the forum.
Old Dec 29, 2010 | 10:59 AM
Gas tank yes, but it is a structural member of the body.
Take it out and you'll have a noodle for a car and for a brain.
Old Dec 29, 2010 | 11:01 AM
The piece of carpeting covering the panel literally will slide out when you have taken all the necessary hardware off, including the umbrella hooks in the center. Once everything is removed, it is one single piece that is shaped like a giant U with the center of the U going over the center console.
Old Dec 29, 2010 | 11:56 AM
You are not suggesting that it be removed I am sure.
As a sheet of 4' x 8' plywood will still not go in it.
Old Dec 29, 2010 | 01:55 PM
microndel's Avatar
I just wanted to know if it is removable. The upper right corner of the map pocket has pulled out and I was thinking that if I could remove the panel, I could reattach it. Any other suggestions out there?
Old Dec 29, 2010 | 02:09 PM
He said Panel so I am assuming he meant nothing more than the 'panel' that covers the subs, wiring, etc. which I tried to assist him with removing. No one is talking about taking a welding torch to the gas tank
Old Dec 29, 2010 | 02:15 PM
bmorgan's Avatar
LOL.... Yep, I did not go down the path of structural modifications when I read the OP. Simple request, and your advice was spot on.
Kodebuster
Nov 5, 2020 04:06 PM
RED DOG
May 4, 2019 08:05 AM
axnguyen
Jul 21, 2015 11:41 AM
2004_
Jul 11, 2015 03:14 PM
jtr2901
Jul 10, 2015 06:33 PM
