Found The Problem (cut Hydraulic Line) Top Won't Work
Old Jan 29, 2011 | 03:48 PM
dkriegh's Avatar
Default Found The Problem (cut Hydraulic Line) Top Won't Work
Found the reason my top woun't work, one of the hydraulic lines was cut in half. Not sure how that happened. it was cut behind the left tail light. I am hoping i can repair it with some type of repair kit. Does anyone know of a repair kit to splice and repair a line? I think I would be a bear to replace.
Thanks For Any Suggestions,
Dennis
Old Jan 29, 2011 | 05:32 PM
Hawk Monster's Avatar
Default Re: Found The Problem (cut Hydraulic Line) Top Woun't Work
Great news. At least you know the problem and saved $4000 to boot. With hydraliics you will need to secure it very tight. You may want to see how much a new line would cost. Also you may want to go to a Checker, etc. and see if they have a hose that your line fits in tightly and put claps on each end. Let us know how it comes out.
Old Jan 29, 2011 | 05:42 PM
Michael M's Avatar
Dennis,
I'm new to Crossfires (and the thrill has not worn off any) so this may not be helpful. I suspect the line is polyethylene or something similar. That's been used for decades, and is the orginal line material on my 67 Dart GT convertible. Compression fittings should be available for polyethylene or steele lines. There will be a fitting between the cut ends. Slinde a nut over the end, then the compression "washer," then tighten. I've used them on water lines and even brake lines, with no failures ever. Unless there is something unusual, the compression fitting should cost only a few dollars.
Good luck.
Michael
Old Jan 29, 2011 | 06:35 PM
GDC-SRT's Avatar
You will need to reset the hydraulic pressure after the repair, as the manual states
Old Jan 30, 2011 | 12:07 PM
dkriegh's Avatar
what is Checker, etc? and I would rather repair the line than pay to have it replaced. do you know the IO Inside and OS outside diameters of the Hydraulic lines what work the top? several people are talking about compression fittings do you know anything about them?
Old Jan 30, 2011 | 12:14 PM
dkriegh's Avatar
Originally Posted by Michael M
Dennis,
Good luck.
Michael
Hello, I am needing more info on these compression fittings etc....where can i get them? can you send me a link on where I might find them? Do you happen to know the size of my line? and what they are called? They are black and look like they are polyethylene...thanks for any help..
.Dennis
678-897-8493
Old Jan 30, 2011 | 12:43 PM
Default Re: Found The Problem (cut Hydraulic Line) Top Won't Work
Since the lines are already broken perhaps you could snip off a small piece to use as a sample to take with you. Checker = Autozone = OReillys. I beleve you should be able to get the compression fitttings at Ace, Home Depot, Lowe's, plumbing suppy. I like the issue of compression fittings.
Old Jan 30, 2011 | 01:47 PM
awilson40's Avatar
Look in the yellow pages for a local Hydraulic shop or industrial supply. Then , as stated above, snip about a 1/2 inch piece off and take it in to the store. Tell them you want a coupler.
They will size it for you and will tell you how to splice the line.
You will want to make sure you have room for a coupler. If the line was cut during operation there might be a pinch point causing the failure. If thats the case then you might want to splice on either side of the pinch point with a new piece of line.
Old Jan 30, 2011 | 01:54 PM
dkriegh's Avatar
Ok thanks for your help I was going to get started tomorrow....Dennis
Old Jan 30, 2011 | 04:48 PM
dkriegh's Avatar
Went out and got the compression coupling and it was a 3/16 or a 1/4 or and 1/8 does that sound right?
Old Jan 30, 2011 | 04:52 PM
sounds about right. Let us know the exact size so I can update my manual.
Old Jan 30, 2011 | 06:23 PM
CharlieO's Avatar
I hope that the repair holds. I think I would be more confident of a complete replacement of the line.
Why am I not surprised that the dealer didn't have a clue what your problem was, but was ready to charge you $4000 to fix it? Or maybe they knew exactly what the problem was, and were going to charge you $4000 for a $150 repair.
Old Jan 31, 2011 | 05:12 AM
crossfirefun's Avatar
When using compression fittings on plastic you have to make sure and use inserts that go into the line to keep it from crushing. These fittings are used in the trucking industry for the air brake lines. Just an FYI so you dont crush the line to small or have it come apart.
tintintoe
Jul 6, 2015 02:47 PM
Wikky
Detail Shop
Jun 15, 2015 12:32 PM
X-fired
Sep 30, 2003 04:11 PM
Rwright2
Detail Shop
Sep 1, 2003 03:40 PM
texex91
Aug 18, 2003 11:08 AM
