What is this "Button" / Fastener in the trunk???
Old Feb 20, 2011 | 10:56 AM
PitMarshall's Avatar
Default What is this "Button" / Fastener in the trunk???
I was in the trunk of the Roadster today, trying to figure out a way to get the panels off that would allow me to run wire from a backup camera to the backup lights. While in there, I noticed that there is a button/fastener on either side of the trunk (picture attached). It seems to be designed to hold something, maybe a cargo net or something. I'm not sure, but it has some function that is not clear to me. Does anyone know what it was designed to do?
At least I know now, that the clips on the panel behind the seats are for umbrellas (and ball caps ).
(BTW, I never did figure out the easy way to remove/replace the back panels of the trunk - behind the license plate and over to the backup lights.) I'm afraid I'll break something.
Old Feb 20, 2011 | 01:40 PM
62thunderbird's Avatar
Default Re: What is this "Button" /Fastener in the trunk???
Cargo net, I believe.
Old Feb 20, 2011 | 09:45 PM
stlas69's Avatar
I have searched for a long time, but can't find any reference to a cargo net. maybe Chrysler never got around to making one for our car. I have looked at other companies nets but none seem to fit
Old Feb 20, 2011 | 10:24 PM
Cargo netting in the trunk of a roadster? Are you kidding?
That might section off a toothbrush
Old Feb 21, 2011 | 03:19 PM
itsky's Avatar
Default Re: What is this "Button" / Fastener in the trunk???
To me it looks like a plastic "rivet"/clip to hold the carpet to the side of the car.
Old Feb 21, 2011 | 05:24 PM
I'd agree, except that all of the other clips/pins made of the same material for that very purpose are different. Clearly, these have some engineered purpose and it seems to be beyond holding the carpet in place - but i'll be darned if I know what it is!
Old Feb 21, 2011 | 05:40 PM
IBLUBYU's Avatar
Seems to me that there was/is a crossfire cover that is made to maybe roll out and cover items in the back of the roadster from view. This might be a dual purpose thingy, that holds the panel on, AND also act as an attachment for the security cover.
Just sayin ....
EDIT... my bad ..... just realized I indicated "roadster" .... the factory cover I'm refering to was for a Coupe. Sorry
Old Feb 21, 2011 | 10:45 PM
P-J's Avatar
P-J
I could see that as a possibility in the Coupe but the Roadster trunk is not accessable from behind the seats...the only way in is through the turnk lid...
Old Feb 21, 2011 | 11:08 PM
Jesus_Christler's Avatar
Originally Posted by P-J
I could see that as a possibility in the Coupe but the Roadster trunk is not accessible from behind the seats...the only way in is through the trunk lid...
There IS a roadster-specific divider but I don't think the stops would hold up the bottom part of the lid. FWIW the coupe buttons are close to there too but more hidden. More than a few pieces are vestigal parts, like the "spoiler" rocker switch on the SRT. I think those buttons are just pop rivets for the rear. Picture of roadster divider below.
Old Feb 22, 2011 | 04:29 PM
Goldwing's Avatar
It looks like a fastener for a cargo net to keep things from flopping around in the boot. Would not be surprised if it was an option for the SLK320 that never made it to our vehicles.
Old Feb 22, 2011 | 06:27 PM
gfalcone's Avatar
There's a trunk in the Roadster ???? Imagine that !!
Old Feb 22, 2011 | 06:33 PM
Those are nuts that hold the side panels in place. You can unscrew them with your fingers.
Old Feb 22, 2011 | 06:56 PM
Bingo! I guess to access the rear tailights. I haven't had to do that yet.
Old Feb 22, 2011 | 06:57 PM
Maybe it should be called the rear glove box.
Old Feb 22, 2011 | 07:37 PM
kurtisberry's Avatar
The coupe has them too, but they on the bulkhead.
Old Feb 22, 2011 | 09:41 PM
A previous post some time ago said that a piece of the luggage set (duffel bag?) clipped to these. I have not tried nor do I know for sure. Seems a bit odd though.
Old Feb 23, 2011 | 10:14 AM
somewhere else in the forums is a note that you do NOT have to remove anything to access the tail light bulbs. All you do is raise the tonneau cover and reach in and change the bulbs.
Old Feb 28, 2011 | 01:33 PM
AlG's Avatar
AlG
Nope, have to remove the interior carpeting to get to the tail lights since they're covered by it. Go in through the trunk, not necessary to have the tonneau open. Takes about 10 minutes a side to do them as I've already done both brake lights on my car.
Osusannah
Feb 12, 2024 01:49 PM
RamblinShamblin
Aug 12, 2017 10:55 PM
Reliableron
Oct 17, 2015 10:19 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
xjken
Sep 13, 2015 10:18 PM
