Crossfire with led running lights just installed
Re: Crossfire with led running lights just installed
between housing & bumper. They (leds) are so small it tucked in nicely. U have to really have to look to see it is not in the lens.
Bought package with 2 strips 28" 14 " total $24.95 at advance auto part #ledlitz white 77015 (TRY THIS NUMBER)
wired direct to cigar/glove compartment fuse. comes on when you start car and stays on. had to use my own wire to get to fuse box, and hide rest of wiring. package says use shampoo & water misted for tight spaces, so U can get in tight and just barley see strips.
Bought package with 2 strips 28" 14 " total $24.95 at advance auto part #10026186
Thanks, but I just googled what you last posted and came up with this.
They look good!!! I did mine using the stripes as well but after 6 months they started burning out. With then they didn't look so good with missing lights. I ended up ripping them off this weekend and now looking into the ones below here...hope you have better luck!!!
Hella Style 10 LED DRL Daytime Running Light Kit - CHRYSLER Crossfire - Newegg.com
OR
M.Benz L Shape 6 LED DRL Daytime Running Light Kit-CHRYSLER Crossfire - Newegg.com
OR
OR
OR
I replaced mine with the Philips Daylight 8 lights. They are really bright and you have the option of wiring them up to your parking lights so that they will auto dim when you turn the parking lights on. If you want to use them as DRL's you will need to wire the (+) to an unused fuse in the engine bay fuse box. I used fuse 12 or 13 (can't remember which) because it turns on with the ignition, but it wasn't hooked up to anything. I'll get pics this weekend. There are lots of videos on YouTube showing installation and how they look afterwards.
gobraves423
06-06-2015 07:03 PM
WindRestrictor
06-01-2015 02:31 PM
gsopc
98
06-30-2005 03:06 AM
