slow filling with fuel...or is it just me ?
Re: slow filling with fuel....or is it just me ?
Originally Posted by awilson40
Man,
I have to hold the nozzle just right and slowly fill to keep the auto kick off from tripping.
Originally Posted by Learnin
Does this happen at different pumps? If so, it could just be the sensitivity of the one pump....if not, I haven't had it happen to my 2007 Roadster.
I have to hold hold the nozzle and a certain point and angle just to keep it from tripping.
on
Re: slow filling with fuel...or is it just me ?
Originally Posted by grayroadster
Mine fills fast, it's painful to put near $50 in it though
The problem we are having is NOT with the PRICE of fuel, rather a PROBLEM FILLING THE TANK USING THE PUMP. THE PUMP SHUTS OFF WHEN HELD ALL THE WAY DOWN. THE FILLER NECK WILL GET CLOGGED WITH TOO MUCH FUEL BECAUSE A VALVE IS STUCK THEREFOR NOT ALLOWING FUEL TO ENTER THE TANK. PLEASE DO NOT SAY ONE MORE THING ABOUT HOW MUCH $$$$$ GAS COSTS.....
Good luck.
I advise you slow your roll. You are asking for help, then getting snippy with a fellow member AFTER someone has posted a possible answer. I'm sure you didn't mean it but it just came off wrong.
The bottom one is a float operated shut off valve that prevents overfilling and would prevent the gas level getting too high in the tank, it also blocks the tube in the event of a car rollover. The other valve is halfway up the tube and prevents blow back of gas. There is another unlikely cause and that would be a foreign object partially blocking the tube.
Access to these valves is very hard as you have to get past the small hole that the pump nozzle fits through. In the event you got to the top valve you would have to get past it to get to the bottom valve.
The manual says that a new tank is the only repair method, but who knows really.
Sorry guys for getting "snippy" or being a little b**** but u gotta understand I was searching for a solution to my problem and all I read was "price of eggs in china" so to say and until onehundred80 posted this bit of tech knowledge I was still in the dark with my problem. And I may not have used this forum much, but I didn't see anything helpful to the original question posted and got mad and vented. Also sorry for the massive delay in response on this topic
If you go through Chrysler for a replacement your looking at $3,000 and the last person waited over six months a year or so ago to get one. I have used tanks available, they are $300 plus s/h.
