peculiar humming sound
Old Dec 27, 2011 | 04:35 PM
sherwinagain's Avatar
Default peculiar humming sound
When I have the key turned to the run/on position I hear an odd low pitched humming coming from behind the air vents. Anyone else experience this?
Old Dec 27, 2011 | 04:37 PM
Default Re: peculiar humming sound
just the fuel pump more than likely...
Old Dec 27, 2011 | 04:42 PM
I'm assuming it's nothing to worry about. I bought myself a crystal red pearl '05 limited roadster on 12-21. Yes, I got an xfire for xmas. 42k
Old Dec 27, 2011 | 09:03 PM
ImportLabSRT's Avatar
Depending on what vents you are talking about, Mercedes put blower motors in the front SAMM box and the passenger floor board compartment to keep the electronics cool.
Old Dec 27, 2011 | 10:45 PM
Without the heater/AC fan on?
Old Dec 28, 2011 | 08:18 AM
Larry Hitze's Avatar
If you don't have the radio on when you first start it up you can hear the secondary air injection pump running for a minute or two. It is kind of a high speed whine comming from the front of the engine. I can hear mine inside when I first start it.
Old Dec 28, 2011 | 10:54 AM
tunaglove's Avatar
It's this. Sounds like a vacuum cleaner. Mine does it until the car warms up a little.
Old Dec 28, 2011 | 10:57 AM
Ah, hell, you get my age, you don't hear any of that stuff. My cars are quiet as a mouse....lol
Old Dec 28, 2011 | 12:34 PM
Goldwing's Avatar
Maybe it's hmming a Xmas song as a thank you for adopting it and giving it a good home.
Old Dec 28, 2011 | 04:01 PM
This is quite possibly true
Old Dec 28, 2011 | 04:08 PM
Most likely the air pump - it does sound like a vacuum cleaner.
Mine runs for about 1 - 2 minutes after start.
Old Dec 28, 2011 | 04:29 PM
turbomar's Avatar
The fan in the ECU/Relay module box started to emit a high pitch whine on my car back in september. I was able to, somehow, quiet it down by moving it(rotate) within its rubber mount. You might want to try that sherwinagain
Old Dec 28, 2011 | 05:18 PM
The humming starts with the key in the "ON" position. the car has not been started. That's what I read in the OP's statement.
So it is not the air pump.
Old Dec 28, 2011 | 05:27 PM
Agreed - scratch the air pump.
Old Dec 28, 2011 | 05:36 PM
Actually as you can see here he says run/on so the pumps back in the running I'd say.
Old Dec 28, 2011 | 05:50 PM
You are a brave man, Larry. When Dave tells me I'm wrong, I just say "yessir" and bow my head.
Old Dec 28, 2011 | 06:19 PM
You may be perfectly correct, but ..... he say says 'turned to the run/on position', he actually never says it was turned past that point and the car started.
I would say the car was running not the way he says it. That's my interpretation, everyone has different ways of saying things, crank, turn over, etc. Shades of gray I guess.
Old Dec 28, 2011 | 06:36 PM
When you put it this way Dave it puts it in a new light and I would tend to agree. I guess we need to know from the gentleman as to whether or not it was actually running or not.
Old Dec 28, 2011 | 06:40 PM
you guys....I am sure if he started it, he wouldn't hear a hum.... He turned the key to the on position...and heard a hum....I can't hear anyway, so I have one quiet car....glad I have gauges so I know I can go....
I don't mean to be brave or contrary, as Dave says to each his own interpretation. That being said I respect Dave for his knowledge and willingness to help anyone that asks.
