Convertible top issues.
Old Feb 29, 2012 | 10:15 AM
jamesclarkie's Avatar
Default Convertible top issues.
Has anyone had any major issues with the convertible top motor or hydraulics??
Thanks,
Jim
Old Feb 29, 2012 | 05:17 PM
Goldwing's Avatar
Default Re: Convertible top issues.
No. Pretty much the top goes down in May and stays down until I garage it for the winter in November. So not much up/down wear and tear. It gets cycled maybe six times per summer. When not driven, it lives in the garage under a cover. 37k on the roadster.
Old Feb 29, 2012 | 07:09 PM
Kodebuster's Avatar
Thanks,
Jim
The biggest issue most have seen is the failure of that pesky divider switch in the trunk, that's located on the top left side, which indicates the divider is correctly in place.
This is the killer that drives many a new owner to drink.
Once you get it nailed down, it's a no brainer.
I think I saw one thread on low hydralic fluid.
But pretty much it's that poorly aligned little switch...
Old Feb 29, 2012 | 07:11 PM
And those pesky little flap cables
Old Feb 29, 2012 | 07:46 PM
lildaddym's Avatar
I have a problem with ours, but it might be an alignment issue...details in a different thread...
Old Mar 1, 2012 | 01:13 AM
Kodebuster's Avatar
Oh, and the other common issue is with the back window coming loose, especially in high heat, high humidity, areas of the country.
Chrysler has a limited recall for full replacement, or seach the Forum, as many have fixed with some cleaning, and a re-glue of the window...
Old Mar 1, 2012 | 03:16 PM
shedman's Avatar
X2 Mine have seized up as you know.Ordered two new ones at £60 ( $93 ) each.
Old Mar 13, 2012 | 03:28 PM
stargzr's Avatar
Should the flap cables be lubricated periodically?
Old Mar 13, 2012 | 08:24 PM
I'm on a business trip, but when I get home, I'm gonna look at mine. I am thinking they SHOULD be lubricated.
Now, as to how and with what.... well, I'm gonna look at this when I get home.
Old Mar 16, 2012 | 10:32 AM
dgon's Avatar
I have a 2005, owned since 2007. The convertible top has worked flawlessly until recently. When I put the top up, the window latch doesn't seat itself (I have to get out and push down so it catches), then the motor quit (or so I thought) working completely. I took it to a dealer and told me they had fixed. It quit working again (assumed motor thing) and took it back to the dealer. The mechanic told me that it's because the cardboard divider ?? in the trunk must always be vertical or the top won't have a place to go). I told him this had never been the case for 4 years, but of course he dismissed me. And now, I have to get out and push the window down again, too. UGH...has anyone heard of this? I want to go back to the dealer and make them fix it, but want to be sure that I have something to present. Thanks!
Old Mar 16, 2012 | 12:05 PM
Kodebuster's Avatar
The purpose of the divider is both as a safety factor, and to ensure nothing is in the way of the Top, as it lowers into the trunk.
If your Top went down without the Divider properly placed (Vertical), then either the Sensor Switch failed, or someone disabled the Switch.
I find it hard to believe that the Dealer was not able to test/fix the Switch for proper operation.
I would make sure this is right, as this pesky little Switch, could be the cause of some of your issues.
The Switch is located on the top Left hand side, where the Divider slips in when correctly in place...
Old Mar 16, 2012 | 12:29 PM
TerryR's Avatar
I agree with this statement. If the Divider is NOT in place and the Microswitch has not activated, the top will NOT move at all, and NEVER will. The microswitch will also not activate if the divider is not properly seated.
If it has worked for the last 4 years and you obviously did not by-pass the microswitch, the shop did, which puts YOUR top at risk of damage.
You probably need a new microswitch assembly.
You can buy the switch assembly for about $25-30, and any layman, even me, can fit it in 10 minutes.
Old Mar 16, 2012 | 02:03 PM
kjwinston's Avatar
No, I have 2 of them with no problem at all. Now when the wife and I were rookie owners and put items in the truck wrong it moved the security wall where the top will lie, and when had concerns witht eh top going up and down, but both of us know now and seem not to have any more problems.
KJ
Old Mar 17, 2012 | 09:18 AM
stargzr's Avatar
I think if the tonneau cover were to be raised manually to a vertical position, perhaps a cable lubricating device like the ones used for motorcycles and bicycles would work. My roadster didn't come with the special tool for releasing the tonneau cover latch and I haven't found a substitute tool yet. I'm not sure that I have what is needed to make one.
Old Mar 17, 2012 | 10:16 AM
lildaddym's Avatar
I open mine with a 5.5mm allen wrench and a 10mm hand wrench...easy once you know the procedure. There is a thread covering that here!
Old Mar 17, 2012 | 10:13 PM
stargzr's Avatar
HOW LONG does that 10mm wrench that unlatches the tonneau cover have to be?
I did find a 6mm allen today and located the rear window latch. Put it in my glovebox just in case.
Old Mar 17, 2012 | 10:41 PM
lildaddym's Avatar
Mine's about 6"...I might do a video of the manual process...
Old Mar 18, 2012 | 12:05 PM
tom diehl's Avatar
I saw that Chrysler recalled some 05's with the window problem. Mine is an 07 and I was able to fix it with some duco cement. Of course, that was 2 weeks ago and there's no telling how long it will hold.
Old Mar 18, 2012 | 12:12 PM
lildaddym's Avatar
According to Chrysler, there is no recall, but the X31 program is an extended warranty program that is for certain VINs delivered to certain areas of the country. Search for it...
Old Mar 19, 2012 | 05:49 PM
KDW4Him's Avatar
Looking forward to the video!
