Conditioner/cleaner for top
Old Mar 31, 2013 | 09:57 PM
Default Re: Conditioner/cleaner for top
you know, I just treated mine. I do this every 6 months and maybe three coats (after the initial treatment) is a bit much.
I used some water to wipe off a spot, and the water is still beading up nicely after six months. I did one coat and will probably not do another this time, at all.
Also, if you get some 303 on the rear window, alcohol takes if off easily!
Old Mar 31, 2013 | 11:21 PM
Abaton6's Avatar
Alright, you guys sold me on the 303. I just ordered a kit from Ebay for 27$ shipped.
Old Apr 1, 2013 | 12:54 AM
Bigkid's Avatar
Thanks Mark, the picture tells the story.
My way of treating the top with 303:
I use garbage bags to protect the car's finish - close the top and windows on them all the way around.
THEN, tape plastic to the rear window.
Then, I spray a fine coating of 303 on the top and kinda buff/spread it with a terry cloth. Let it dry in the sun up to four hours.
Repeat (maybe the next day if you could not let it set in the sun).
Repeat again.
This three - coatings treatment should take almost 1/2 bottle. Do this every six months and I am telling you:
1) You will be as protected as possible from UV.
2) The top will never get dirty, other than what you can clean off with water and a towel - not only willl water not cling to the top, nothing else will, either!
3) You can get the top SOAKED wet, wipe it off with towels, and in 5 or 10 minutes, it's so dry you can put it down without worry of shrinkage!
See picture - I call it "The Aunt Jemima Treatment"!
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
Mackel
Oct 16, 2015 09:03 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
