engine oil light keeps coming on
Old Apr 21, 2013 | 09:05 PM
Red Racer's Avatar
Default engine oil light keeps coming on
Red engine oil light keeps coming on. I had my oil changed, the receipt says 9 quarts then drove 1800 miles no problem. Then the engine oil light came on, slow down the light goes off, speed up it goes back on. Checked the oil and it looked ok. Dash says oil is ok. Drove 1500 miles and now the oil is brown? Help!
Old Apr 21, 2013 | 10:22 PM
Abaton6's Avatar
Default Re: engine oil light keeps coming on
Install a pressure gage, and see if the pressure is really going down at high speeds. If it isn't, it's your oil pressure sending unit lying to you.
Old Apr 22, 2013 | 12:25 AM
magneticred's Avatar
Was the oil level near full on the dip stick. From the manual:
if the low engine oil
level warning lamp comes on, a malfunction in the
engine oil level system is indicated. A conveniently
located dipstick allows manual checking of the oil level.
If no leaks are noted, continue to drive to the nearest
service station where the engine oil should be topped to
the “full” mark on the dipstick with an approved oil.
Old Apr 23, 2013 | 03:54 PM
Red Racer's Avatar
took it in and had the extra oil removed. Was way over the max mark. Engine light is still on. They will replace the oil sensor. I keep you up to it. I told them to do an engine analysis to see if there is any other damage to it. Any other suggestions?
Old Apr 23, 2013 | 03:58 PM
AlG's Avatar
AlG
Had the oil sensor in the oil pan replaced on my car too. Was done at the dealer under the extended warranty. Went out the next morning there were about two quarts on the ground. Back to the dealer, tech cracked the oil pan when he replaced it so I got a new pan too. Just saying, watch out for that happening. May have just been mine but you never know.
4drturbo
Jan 3, 2019 02:46 PM
jgreen
106
Sep 18, 2017 11:46 PM
reiji
Oct 15, 2015 10:50 PM
axnguyen
Jul 21, 2015 11:41 AM
skeet370
Jul 18, 2015 01:02 PM
