'06 Crossfire won't start no lights or power.
Old May 15, 2013 | 03:40 PM
Keburton's Avatar
Unhappy '06 Crossfire won't start no lights or power.
We took our 06 Crossfire out of heated storage 3 weeks ago and it worked great. no issues. Went out today and it won't not turn over and no light appeared on the dash. Tried to start it using a boost and still nothing. An ideas on what could cause this?
KBurton
Old May 15, 2013 | 04:19 PM
Mrmiata's Avatar
Default Re: 06 Crossfire won't start no lights or power.
https://www.crossfireforum.org/forum...tml#post739727
Old May 15, 2013 | 06:22 PM
KBurton
If no lights at all even with booster battery connected, then I'd be looking at the battery to frame ground wire. ( the negative terminal cable )
Do this :
1. using a multimeter, check voltage on battery across the poles.
2. If you see 12+ volts in step 1, then check from the positive of the battery to some part of the engine / frame. If no voltage, then you have ground ( negative battery cable ) issues.
Old May 15, 2013 | 06:59 PM
Mrmiata's Avatar
KBurton
Once again "interpretation" .. lol. single light (as in cel) or no lights..
Old May 16, 2013 | 06:46 AM
Yep. The devil's in the details, right ?
See the thread title :
Old May 28, 2013 | 11:17 PM
Ian Michaels's Avatar
Default Re: '06 Crossfire won't start no lights or power.
Try checking the ground cable on battery. Had the same problem and cleaning it up and tightening it down fixed it;
Old May 29, 2013 | 04:34 AM
Dead battery. Let her charge for awhile then try to jump start it. Mine did this a lot with the little drag racing batteries. Didn't want to jump start until there was some charge in there.
foxy1305
U.K.
Jan 1, 2020 11:41 AM
smmanley1996
Sep 4, 2015 04:40 PM
carmax
Jun 18, 2015 01:30 PM
MJPowers
Jun 8, 2015 02:34 AM
texex91
Nov 20, 2003 06:00 PM
