instructions on replacing a blown rear brake light on convertable
Old Dec 27, 2014 | 02:12 PM
figgy7935's Avatar
Default instructions on replacing a blown rear brake light on convertable
Looking for some instructions or video on accessing the rear brake light on a crossfire roadster.
Old Dec 27, 2014 | 02:18 PM
lildaddym's Avatar
Default Re: instructions on replacing a blown rear brake light on convertable
There is a thread, but the easiest way is to lift the top so the tonneau cover is open.
Old Dec 27, 2014 | 02:24 PM
figgy7935's Avatar
someone else had suggested the opening of the top. They mentioned you only have 10 mins before the toneau cover comes down. Worried about that damaging the cover
Old Dec 27, 2014 | 02:31 PM
lildaddym's Avatar
I think it's recommended to find a stick long enough to hold it up....it took me less than 10 minutes to get it done.
Old Dec 27, 2014 | 10:12 PM
I use my hiking "trekking pole" (which is a telescopic walking stick that can lock in any length).
Use it to prop the cover up. The window will also relax, don't worry about it. Use techniques from the manual procedure to return the top to all-the-way-up or all-the-way-down if you need to.
Old Dec 27, 2014 | 11:36 PM
turbomar's Avatar
FYI, the roadster taillight bulbs can be replaced via the trunk lid.
Thanks for the video, could come in handy, specially if I ever own a roadster!
Old Jan 6, 2020 | 08:48 PM
Garco57's Avatar
What is the number for the brake light bulb??
Old Jan 6, 2020 | 10:20 PM
2005 CHRYSLER CROSSFIRE
LOW BEAM HEADLAMP H7
HIGH BEAM HEADLAMP H7
FOG/DRIVING LIGHT 9006
PARKING LIGHT 2825
FRONT TURN SIGNAL 7507
REAR TURN SIGNAL 7507
TAIL LIGHT 7528 ( 1034 or 1157 )
BRAKE LIGHT 7528
BACKUP LIGHT 7506
FRONT SIDEMARKER 2825
REAR SIDEMARKER 2825
GLOVE BOX 6418
STEP/COURTESY LIGHT 6418
TRUNK/CARGO AREA 6418
Old Jan 7, 2020 | 01:13 PM
REAR TURN SIGNAL 7507 - Yes
TAIL LIGHT 7528 ( 1034 or 1157 ) - ?
BRAKE LIGHT 7528 - Yes
BACKUP LIGHT 7506 - Yes
I see three bulb sockets in the Tail Light assembly, How come there are four bulbs listed? The Brake and Tail lights are combined as a double filament bulb.
This list has been around for years but lists too many bulbs.
Old Jan 7, 2020 | 01:16 PM
Agreed. I do not recall where I copied that list from.
Old Jan 7, 2020 | 06:07 PM
The first list I saw that on was one posted by andrew. CLICK
Old Jan 7, 2020 | 06:37 PM
Well at least both are listed as the same bulb type.
BibaResto
Jul 4, 2015 03:20 PM
syfi
Jun 22, 2015 07:23 AM
WindRestrictor
Jun 16, 2015 12:18 PM
rmcdaniel12
Jun 10, 2015 03:51 PM
WindRestrictor
Jun 1, 2015 02:31 PM
