sticking top
Old Apr 3, 2015 | 10:57 AM
Default sticking top
Can anyone tell me where all of the lube points are for the roadster top? Mine seems to be sticking on occasion and I get the dreaded beep. After a couple of tries I hear the latch finally release and it opens fine. I can't help but think the latch is sticking. Does anyone know hat would be a good lubricant?
Old Apr 3, 2015 | 11:03 AM
Default Re: sticking top
I use a spray can of white lithium grease.
Old Apr 3, 2015 | 05:14 PM
TopHydraulics's Avatar
Sponsor
Convertible top frames do not normally need to be lubed. Even the two hydraulic latches come well lubed from the factory, and I haven't seen a case yet where they would be sticking on account of friction. The rear bow lock in the Crossfire can potentially have crud around the micro switch, but that is not a lubrication issue and it doesn't match your symptoms.
If the rear bow latch does not always release, then I would check the hydraulic fluid level in the pump first.
Klaus
Top Hydraulics | Rebuilt and Upgraded Convertible Top Cylinders, Pumps, Hydraulic Lines - Top Hydraulics, Inc
Old Apr 3, 2015 | 06:19 PM
Thanks for the feedback.
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
Sterling57
Apr 11, 2016 06:11 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
