Battery recommendations
Old Aug 16, 2015 | 03:13 PM
Rets's Avatar
Default Battery recommendations
Changed my oil this morning and checked the date on my Battery!
2011, I'm thinking i should since when they go they don't leave a note saying goodbye!
What's the best!
I see these racing battery's but that doesn't give you longevity does it?
Old Aug 16, 2015 | 03:23 PM
jayloukakis@hotmail.com's Avatar
Thumbs up Re: Battery recommendations
What's the best!
I would go with an AGM if you don't know what they are, several MFG. make themeven Sears has them.
Old Aug 16, 2015 | 03:29 PM
Default Re: Battery recommendations
I got this one, very satisfied :
Search Page
Old Aug 16, 2015 | 04:35 PM
Definitely go with an AGM battery, still a little more expensive, but you can forget the spills that eat your car while you are not looking.
Old Aug 16, 2015 | 05:48 PM
What's the best!
When you say racing batteries Exide does a lot of Adds but they build the worst automotive battery, the other one That sells a lot of adds is the Optima round cell, at one time GNB sold it, GNB auto is one of the worst, how can I say this I worked for Exide industrial for over 13 years, then I worked for GNB industrial batteries neither company made cast grids for the auto batteries, I have been retired from that industry for 17 years. GNB for 8 1/2 years.
Old Aug 20, 2015 | 01:43 AM
kjwinston's Avatar
In the West" Les Schwab, 8 year Battery.
Old Aug 20, 2015 | 09:33 PM
Goldwing's Avatar
Defintely AGM. My SRT6 was leaking a little acid and eating away the paint. Cleaned it all up and replaced a perfectly good battery - no more problems. Did the same a month later for the 'vert. Just good insurance.
Old Aug 21, 2015 | 07:54 PM
Rets's Avatar
I found a AGM battery at Walmart same battery at NAPA and Advance for $50 bucks less
Will pick one tonight, is the radio the only thing I need to reset?
Old Aug 21, 2015 | 08:00 PM
What Mfg. Exide sells a sealed battery but it is a gel cell, not what you want, some are made by Johnson Control.
Old Aug 22, 2015 | 07:22 AM
Probably too late, but see post #3. Really top notch AGM battery from East Penn, about $180 with shipping to Nashville.
( and YES, radio is all that will need resetting, remember, negative off first, negative on last )
Old Aug 22, 2015 | 01:48 PM
SOMETIMES, people say that the brake system light comes on with a battery reconnection. Never has happened to me, but some report that.
Just do the wheel-all-the-way-to-the-left-then-all-the-way-to-the-right thing and you should be good.
Old Aug 22, 2015 | 03:54 PM
I have one of those gadgets that uses a 9V battery to apply power through the cigarette lighter and it works great. Just the trickle power keeps all of the presets while changing batteries. It's called a Settings Keeper.
Old Aug 22, 2015 | 06:50 PM
pioneer4x4's Avatar
I think that it is triggered when the steering wheel is not centered when the battery is reconnected. I saw the same thing on my 06 Charger
Old Aug 22, 2015 | 08:50 PM
Goldwing's Avatar
I've disconnected and removed the batteries multiple times on both cars and never had to reset anything. Much easier than my freaking Audis.
Old Aug 22, 2015 | 10:36 PM
I would say that is probably correct, my OEM radios always kept the presets and only once did the steering have to be reset. It probably was not on center as you say.
Old Aug 23, 2015 | 12:12 AM
chturner's Avatar
I get a battery light every time but it always goes away when i turn the wheel. My aftermarket radio always resets my settings, but I am not sure what you have.
Old Aug 23, 2015 | 06:18 PM
I'm not sure who your response is referring to.
My OEM always kept the settings but my new Kenwood forgets everything.
Old Aug 23, 2015 | 06:31 PM
chturner's Avatar
No one in particular. Just adding my experience to the conversation. I love redoing my settings
blackpepper
Oct 4, 2017 06:09 AM
o55ie18
Oct 5, 2015 05:50 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Valk
Sep 17, 2015 11:43 AM
