Unsafe Car
Old Feb 7, 2005 | 08:10 AM
Playboy's Avatar
Default Re: Unsafe Car
I have the same problem. Took it to the dealer the second time and they said they think its the throttle body. Waiting for new part to come in. I'll post if it solves the problem.
Old Feb 7, 2005 | 11:09 AM
cwdilg's Avatar
At 5000' altitude in New Mexico, you should be running with PREMIUM octane to avoid engine knocking. Dealer is wrong on this one. I run on SHELL 91 here in Colorado, and no problems whatsoever. At this time of year, you can plug your injectors by running inferior brand gasoline, especially the incorrect octane, stay with a brand name. Get back on a steady diet of the correct gasoline.
Old Feb 7, 2005 | 03:56 PM
Epyon
Guest
Posts: n/a
hey, when you spend 45,000 thousand DOLLARS ON A CAR, YOU WOULD EXPECT THE TRANSMISSION TO WORK.
Old Feb 7, 2005 | 06:56 PM
HDDP's Avatar
YIKES !
I agree, You should be pissed, but I usually call the other forum members KNUCKLEHEADS when they say something stupid...
Old Feb 7, 2005 | 08:15 PM
Dan Root's Avatar
Banned
I thought Xfires are going for 10k under! closer to $25-27k.
Old Feb 7, 2005 | 09:00 PM
Epyon
Guest
Posts: n/a
its a roadster, and yea, knucklehead sounds less intrusive.
Old Feb 7, 2005 | 09:02 PM
Dan Root's Avatar
Banned
Roadsters here start around 32KBase
Old Feb 7, 2005 | 09:23 PM
Epyon
Guest
Posts: n/a
hell no 32k base, 35k is the base, i thought with Limited trim (auto) comes to around 40k with taxes.
we are getting a new car next weekend.
Old Feb 7, 2005 | 09:33 PM
buckeyedad42's Avatar
I would not listen to anyone teling you to put anything less than 91-93 octane in it as the manual says. It will knock as dan root says and someone else on this forum said they used regular and their catalytic convertor went south in 500 miles. I personaly don't understand that unless the the person went and put LEADED regular in which would do that. But they said it not me.
Old Feb 20, 2005 | 01:35 PM
rpr1bob's Avatar
Lightbulb Re: Unsafe Car
on the 6 speed, if the engine dies it will not restart until the key is turned off and then on again. Maybe the auto is the same.
Old Feb 21, 2005 | 10:08 AM
C_Plunkett's Avatar
I would think the auto would be that way as well. It's made that way to keep someone from turning the key and engaging the starter while the engine is alreay running.
Old Feb 21, 2005 | 01:03 PM
Bob G's Avatar
i was driving down the road, and there was a truck blocking the road.
i stopped fully, and changed the auto tranny to R (revese)
the car didnt move.
i changed it back to drive, it didnt move.
restarted the car, and the tranny worked.
piece of crap.
Computers!! I assume that you are aware form another post, that if your auto transmission has a clitch the computer will register the "clitch" in the system for a Tech to see later when he does a diagnostic on it. Plus, if it is a descent "clitch", it will stop the transmission from working. You have to shut off the engine, shift to park, wait 10 seconds, restart and you will have reverse and 2nd only to limp home.
That sounds like what happened to you. Dan, sorry if I repeated myself, but I quickly scanned the thread and didn't see the above response.
Old Feb 23, 2005 | 01:15 AM
HDDP's Avatar
No kidding, I did a major spin at Button Willow Raceway in the chicane and stalled the car with a few other sports cars on my ***. I tried to restart FAST... No, go !!! Till I figured out the "Turn the key OFF" issue... Wasn't pretty...
Old Feb 25, 2005 | 08:19 PM
Bob G's Avatar
Oh, Crap!!
How did you stall it? Your fault or mechanical?
Old Feb 25, 2005 | 10:18 PM
HDDP's Avatar
Originally Posted by Bob G
Oh, Crap!!
The stall was my fault. I spun the car twice and didn't get to the clutch fast enough to keep the engine idling.
Once the car setteled enough to try to re-start the engine (or my brain was clear enough) I just turned the key from the current on position to start and then NADA... Not realizing I had to turn the key completely off, then on before the starter would engage.
Once I figured out that little tid-bit of information, the re-start was a bit of a pain since I usually run with only enough gas to make the laps I'm doing and I must have sucked air into the injectors during the spins and the car wouldn't fire immediatly...
To make things worse, I was on the outside apex of the last turn in the chicane, with quite a few other cars trying to avoid me... Bare in mind, this all took place in less than a minute...
All in all, the car has always worked like a CHAMP for me. Granted, it's underpowered, but I have had some serious fun with it on the track...
I hope that in the next year or so I'll have enough money to turn it into a serious competitor... If there are any sponsors reading this thread, drop me an e-mail !!!
Old Feb 25, 2005 | 10:35 PM
Dan Root's Avatar
Banned
How much was the speeding Ticket?
Old Feb 25, 2005 | 10:39 PM
HDDP's Avatar
$638.00, Why ?
Old Feb 25, 2005 | 10:43 PM
  #38 (permalink)
Dan Root's Avatar
Banned
just saw that in your sig. the busted.
Old Feb 27, 2005 | 02:00 PM
  #39 (permalink)
blackal's Avatar
Epyon, don't worry about Root and Byars, they obviously are not nowledgable anyway. There is a lot of good information on this site. So throw out the garbage some of these guys dump on the site and enjoy the good stuff.
Old Feb 27, 2005 | 02:08 PM
  #40 (permalink)
Epyon
Guest
Posts: n/a
yea, your right.
