Trailer Hitch
Old Apr 23, 2018 | 09:09 AM
Speedy4x4's Avatar
Default Re: Trailer Hitch
I have liked this setup, thought about if the bars where just alittle longer, and flipped up so the bar would be above the exhaust instead of under.
Old May 7, 2018 | 11:35 AM
buford05's Avatar
I finished mine and pull a small cargo trailer that I towed with my Ultra all over America even to Newfoundland and Labrador. The reciever is 1 1/8 th and I made a solid steel ball connecter. The hitch is polished stainless and made a little like the Chrysler emblem. And no I'm not going into production. I just can't understand the elitists that consider modifieing a crossfire a crime. It's a car, they don't complain about a hemi mod. I drive mine in good weather and have over 90,000 on it. I have Borla exhaust.
Old May 7, 2018 | 11:49 AM
Gee golly wow ! Wish you would go into production, at least for me
Old May 7, 2018 | 03:05 PM
buford05's Avatar
Sorry I'm afraid time is not as available as it used to be. I go to Florida in the winter now and it seems as though summers are too short. It takes alot of polishing and fabricating. I drilled the rear cross member so it will bolt in. I can stand on the ball ( 6' 3 x 270 ) and it doesn't flex. The trailer loaded is only about 250 to 300 lbs with 25 lbs of toung weight . But thanks all the same.
Old May 10, 2018 | 11:56 AM
BibaResto's Avatar
Default Trailer Hitch
Apparently the fewer words you use the better your chances of finding what you want.
https://www.carid.com/2005-chrysler-...ailer-hitches/
The sooner I can get a tow hitch along with a wheelchair mount, the sooner I can go between living at an Extended Stay America and my shop seven miles away. Of course with a helper to assist me.
So if anyone else is doing something similar, let's get together.
Sorry about butting into this thread.
Old May 10, 2018 | 01:07 PM
Your not butting in at all
I'm glad you found what you were looking for ....that is what this forum is all about
My best to you
Gary
Old May 10, 2018 | 01:25 PM
dizzyspots's Avatar
Since we are not talking about pulling boat trailers etc...look at the touring motorcycle (Goldwing, Harley and BMW) market for hitch ideas...most all of them use the 1-1/4" ball mounts and either 1 7/8" ***** or heim joint style pin couplers...the smaller ball mounts ease the fabrication challenge a bit...some of the simpler bolt on variety might be adapted to a Crossfire...just my 2 cents
Old May 31, 2020 | 11:46 AM
Either I am missing something or the link isn't right? Where is the hitch for the crossfire? All I get on that link is a listing of over 2,746 items! IS THERE a hitch that mounts to a crossfire on that site?
