Transmission help
Old Feb 20, 2018 | 11:16 AM
jrmirsh1's Avatar
Default Transmission help
I live in Frankfort KY and need to find a good transmission person who works on the crossfire automatic. Does anyone know of a good and honest person with in 100 mile radius of Frankfort? My 2005 crossfire roster with only 22000 miles needs some help. Any help would be appreciated.
Old Feb 20, 2018 | 11:23 AM
Default Re: Transmission help
What are the symptoms?
Old Feb 20, 2018 | 01:24 PM
harbor's Avatar
No first hand experience with any of these shops, but it’s a start:
https://www.benzshops.com/search?q=Frankfort%2C%20ky
Old Feb 20, 2018 | 02:12 PM
jrmirsh1's Avatar
first to second it has a jerk, took to Chrysler dealer to have them do a transmission adaptive reset and to see if there were any codes showing up . No codes and they said they tried to do a transmission reset but said it didn't do any good. they couldn't really say what was wrong but that it would be a lot of money to fix. the car shifts fine in all other gears it only jerks when you start of between first and second and when your slowing down from second to first.
Old Feb 20, 2018 | 02:15 PM
May try replacing the conductor plate and a new set of solenoids.
Another thing to try : put the selector switch in "W" - makes it start off in second.
( Like the doctor said "If it hurts when you do that, don't do that" )
Old Feb 20, 2018 | 02:57 PM
Steve Jr's Avatar
Good advice, with fluid an filter......an not just 4 qts.
Old Feb 20, 2018 | 11:05 PM
maybe you should call matt,, maybe he could build you a tranny ship it to u , or come to you and rebuild yours as he will be in north Ga. soon. jim
https://www.crossfireforum.org/forum...=mercedes+matt
Old Feb 21, 2018 | 10:50 AM
Padgett's Avatar
Well before replacing or rebuilding a transmission I would add a can of Seafoam TransTune and drive a bit. Have had shuttle valves get sticky before in my cars and usually clears it up. A transmission oil change after a couple of hundred miles would not hurt.
Has anyone else here used TransTune ?
Old Feb 21, 2018 | 11:13 AM
The Chrysler dealer would be the one I would least trust. These are Mercedes transmissions and they have no clue. If you don't want to mess with it yourself , at least try and independant shop that understands Mercedes.
Old Feb 21, 2018 | 01:10 PM
jrmirsh1's Avatar
Thanks Padgett for that great idea, I will get a can today and see if it helps. Will keep you posted and thanks to the forum and all the great guys for all of the help!!!
Old Feb 21, 2018 | 01:28 PM
Padgett's Avatar
You are welcome. BTW Chrysler used A Lot of NAG-1 (WA580 / W5A580) transmissions, my '12 Jeep has one (large case) so a Chrysler dealer should know how to work on one but may not. Agree unless under warranty I would not go to one either.
Old Apr 1, 2018 | 02:01 AM
RamblinShamblin's Avatar
In case you haven't yet got your car repaired: I just had a similar problem with my '05 transmission not shifting beyond 2nd gear. My local Chrysler charged me $200 to "diagnose" the problem, telling me the transmission was beyond repair, new transmissions are not available and replacing it with a rebuilt or salvaged transmission was not recommended because "they rarely work". The rep then asked my if I'd like to talk to her about making a trade-in on a new car. After thinking it over for a millisecond I said, "Uhmmmm . . . . no."
I went on line and found that there were lots of new, rebuilt and used transmissions available for $500 to $2000 and labor usually runs about $600 to $800. I sucked in my belly and took my car to a local transmission shop after making a few phone calls and getting good reports on his reliability. He fixed it in 4 days for $442. The problem was not the transmission but the line that carries multiple communication wires from the engine computer to the transmission, telling it how many RPMs the engine is making.
The dealer can bite my shiny metal ***.
Jocko124
15
May 16, 2019 04:24 PM
Dnivek
Apr 24, 2013 05:20 PM
chuckman031886
Nov 29, 2011 10:46 PM
robjob941
Nov 15, 2010 09:52 AM
OC Xfire
Mar 30, 2009 06:39 PM
