Hydraulic cylinder disassembly?
Old Feb 16, 2019 | 09:11 AM
DualSportDad's Avatar
Default Hydraulic cylinder disassembly?
i'm wondering if anyone can give me some advice about how to remove the bottom end cap on the main cylinders? i'd normally send these out for a rebuild but i'm trying to have it fixed by sunday night.
Old Feb 16, 2019 | 10:52 AM
Default Re: Hydraulic cylinder disassembly?
Not sure what you are talking about??
Old Feb 16, 2019 | 10:55 AM
I believe (I could be wrong) that where the lower pin goes through the main cylinder body is a separate piece and can be removed. It almost looks like the bottom is crimped. I'm trying to separate that piece and replace the o- ring.
Old Feb 16, 2019 | 11:45 AM
You may want to look through this thread. The only O-rings you may be able to replace yourself are where the lines go into the cylinders.
https://www.crossfireforum.org/forum...ic-system.html
Old Feb 16, 2019 | 02:15 PM
Im fairly certain I can cut just the lower section of the body on the cylinder off (like 1/8th inch) to release the clamp and then separate the bottom.
That being said I sent mine out. I have other stuff to address on my car and the weather will be nice next weekend as well, hopefully I'll have them back by then. I'll inspect the body of the cylinders and possibly buy a used one and rebuild it myself in hopes I can offer same day service to my customers.
Old Feb 16, 2019 | 04:41 PM
Keep us posted.
Old Feb 16, 2019 | 05:34 PM
Keep us posted.
I will. Not sure how much I'll want to invest in cylinders, looks like crazy money for them in eBay in used condition. I'll get one soon enough I'm sure.
Old Feb 16, 2019 | 05:58 PM
If you read the string there is a company named Top Hydraulics that rebuilds them for $150.00 each.
Old Feb 16, 2019 | 06:06 PM
Thats who I use through work but for my personal ones I sent them to cabriolet hydraulics. Top hydrolics is all the way across the country and usually take 3 weeks to get back to me, cabriolet is 2 hours from where I live and said they will do them same day and have them shipped back to me that day or the next. I'm just hoping to have a working top by next weekend is all. I also ordered a new cover from BAS. No rush really for that really.
Today I put in a new ignition lock housing after I did the stuck key mod. Next is a 60k service, I'm at 67k.
Old Feb 17, 2019 | 10:46 AM
Iamfink2's Avatar
When I had mine rebuilt after I removed them from the car I just put the top up manually and still drove the car. Just wrap the end of the hydraulic lines with a towel for any leakage you might get putting the top up and down manually. I would still put my top down to drive if it was nice outside until it was fixed.
Old Feb 17, 2019 | 12:31 PM
Thanks, that's what I did and it's what I do for my customers as well I just tell them not to use their top at all. If I recall the top kinda takes off on you once to release the top latch and there's no cylinders. I could be wrong. I'm sure if it's nice out and I don't have the cylinders back I'll just put it down manually.
Old Feb 19, 2019 | 10:43 PM
Looks like they did indeed cut the bottom. So if I think I know how it comes apart... The top of the for gets screwed off and the bottom get removed and the cylinder gets slid off the rod. I'll keep my eye out for a used one.
Edit: first picture is rebuilt one, 2nd is stock, before rebuild.
Old Sep 16, 2020 | 08:59 PM
kernol2's Avatar
I also had a cylinder concern. I did disconnect the cylinder and replaced the o rings on the lines to the cylinder in hopes it would be a cheaper fix. It did not work. I had to order the new cylinders from Top Hydraulic.
XFireCrazy
Sep 16, 2020 09:01 PM
stevieb
Feb 2, 2017 08:08 PM
donstar100
Aug 28, 2012 09:35 AM
rdooley79
Jan 29, 2010 09:35 PM
the.Santorini
Jan 25, 2009 03:38 PM
