Dual mass flywheel
Old Mar 26, 2019 | 03:10 PM
bertiewooster's Avatar
Default Dual mass flywheel
Hi folks
My clutch has gone and it's in a local garage
I eventually managed to get one shipped from USA to UK but when they dismantled it they found it had a dmf which was knackered and there does not seem to be any available in the UK.
They ate wondering if it can be changed for a standard flywheel but cannot find a lot to do this.
Has anyone any info on this Please?
Old Mar 27, 2019 | 07:03 AM
Speedy4x4's Avatar
Default Re: Dual mass flywheel
Originally Posted by bertiewooster
Hi folks
I looked in some and to see if there was a single mass flywheel, found some aluminum smf custom made, don't remember where.
Check with the wrangle since they use the same 6 speed transmission, but different spline input shafts, so the clutch will not work, but if you count the teeth on the flywheel, can match up to find other flywheels, once you find the tooth count, then look at the center bolts, when you get those 2 to match, good chance you can make it work
Finding a matching clutch would be using a spring clutch, OEM does not have springs in clutch they are in the flywheel, just March the spline count and the diameter and should work.
I was wanting to do alot more on this, but want a used dmf and clutch from someone, asked a few on forum before when they where getting theirs done, but got nothing.
kinkladze
U.K.
Jul 6, 2013 03:20 PM
maxcichon
Jun 19, 2013 07:04 AM
funky_beatz12
New England Forum
Jul 16, 2008 04:52 PM
Nightrider
Car Shows
Jun 27, 2008 01:08 PM
grphtmtlc11
Other Cars Etc
May 21, 2007 02:46 PM
