Roadster Rear Window Repair Question
Old Jul 8, 2020 | 07:46 AM
Bargegeek's Avatar
Default Roadster Rear Window Repair Question
As is typical, my rear window is starting to separate along the passenger side bottom. Can a "spot repair" provide enough weatherproofing, or should I (sigh) remove the entire window and glue/seal the whole thing?
I got all the 3M window weld, primer and glass clamps. Thanks.
Old Jul 8, 2020 | 04:27 PM
Default Re: Roadster Rear Window Repair Question
I resealed mine when it was about half loose about 6 years ago and it is still holding however I keep mine garaged.
Old Jul 9, 2020 | 04:17 PM
P-J's Avatar
P-J
I resealed mine when both bottom corners started to separate, it lasted about six months then it started separating on the sides and on the bottom from where the repairs were made. Again, fixed this and it lasted about three months in the dead of summer started seperating where it was not repaired. Maybe i should have separated the window and repaired it all the first time but did not, I replaced the top last September and couldn't be happier with it. Good luck with your repair, there is a sticky on how to do this.
Turbo-Duck
Jul 6, 2024 08:18 PM
ZERACER
Sep 14, 2016 08:23 AM
ibedoughboy
Dec 23, 2012 08:28 PM
magredvet
Jul 16, 2012 02:58 PM
srafferty
Mar 14, 2012 08:18 PM
