Top will not go down
Old Feb 7, 2023 | 04:47 AM
RASCAL73's Avatar
Default Top will not go down
It's been working fine all of a sudden it will not go down.
I though it was the curtain in the trunk but its in place.
​​​the.any suggestions?
Dennis
Old Feb 7, 2023 | 11:45 AM
UrbanE's Avatar
Default Re: Top will not go down
1 simple, fast suggestion. Although the truck divider (Curtain) may be in place, it might not be correctly engaged in the bracket on the driver's side. The Left side has a top switch incorporated into the bracket. This happened to me, I changed the bracket, and it started working.
While there, check to see if the bracket is in one piece, sometimes they crack and when they do, the divider and the switch will not correctly engage. YOU WILL NEED TO REMOVE THE LINER ON THE DRIVERS SIDE IN THE TRUNK
If you don't already have a spare (impossible to find) set of trunk divider brackets, they can be purchased (Reproductions) here on the site, I believe it's forum member Shamrock. I purchased a set. great quality worth every penny
YOU CANNOT LOCATE THESE USED ANYWHERE UNLESS YOU'RE THE FIRST GUY TO COME ACROSS IT AT A BREAKER YARD.
Please keep us posted on the developments. If it's the bracket, PLEASE let us know.
Wishing you success in correcting your issue.
Old Feb 7, 2023 | 12:08 PM
dcskmail's Avatar
Here's several videos for trouble shooting the top, pull up youtube and type: "crossfire convertible top issues" in the search field
Old Feb 7, 2023 | 12:25 PM
Thread moved to Roadster forum
One way to find out where hte problem is, is to put the top down manually. THEN, press the button to put it up.
If the top will go UP but not DOWN, it's either the "top open" switch over the passenger's head or the divider switch in the trunk.
If it won't go UP or DOWN, then it can be the CLP/SSM, the BCM, low fluid, bad trunk closed sensor or a list of other items.
But putting it down manually and seeing if it will go up will certainly tell you if it's one ot the two switches I mention.
Here are two "How to put the top up and down manually" videos:
maggy55
Apr 6, 2017 10:42 PM
Pjj51
Sep 27, 2016 10:00 PM
ncarter
Feb 1, 2016 07:25 AM
Rapps
Oct 17, 2007 06:55 AM
