'05 SRT boost level? Need more boost!!
Old Apr 27, 2006 | 04:46 PM
petez Racing's Avatar
Default '05 SRT boost level? Need more boost!!
Hey XF'ers,
I'm new to the Crossfire as of my purchase last week. The power is nice but, I'm use to more, what is the stock boost pressure, and does anyone make different pulleys to up it?
Thank you
Pete
Adrenalin is 100+ M.P.H. 100 feet before a 90 degree turn!
366 H.P. 418 Torque 240Z 2,300 Lbs 6cyl @ 14 P.S.I. 90 Octane
<http://www.cardomain.com/ride/2116389>
Old Apr 27, 2006 | 09:25 PM
SRT6_Roadster's Avatar
Default Re: 05 SRT boost level? Need more boost!!
Stock is one bar (14.7 psi). Plenty of companies make upgraded pulleys -- RENNtech, Kleeman, ASP, Evosport among others.
Old Apr 28, 2006 | 11:28 AM
Thank you,
I will look into them. Has anyone changed out the pulley and to what pressure/bar? Does anyone have Dyno results and how did the ECU handle the change, heck if I'm asking has anyone found the answer as to what the factory warranty will do with aftermarket boost?
Have an awesome weekend.
Pete
Old Apr 28, 2006 | 12:27 PM
Eracer76's Avatar
I've been reading the forums for almost a month now. I've done many searches, but I can't seem to find anyone that has actually changed out their pulley/s.
Am I wrong, has someone done it yet?
As soon as I get my SRT6 that's on order, I'll sell my SRT4 and use some of the money to mod the SRT6.
Maybe I'll have to take the chance and be the first one to spend the $,2850 or so that the pulleys/ECU upgrade kits cost.
Old Apr 28, 2006 | 01:35 PM
Eracer76,
I need to learn more about my engine. I have been into Z's for many years time to understand the SRT. If the ECU runs with a MAP sensor no ECU upgrade would be needed just a pulley.
Pete
Old Apr 28, 2006 | 02:13 PM
Eracer76's Avatar
With the reading/research I've done, there are companies out there that make pulley kits.
Their kits seem to be changing out all the pulleys but the supercharger pulley. They still get more boost by making the crank pulley bigger.
I believe that the supercharger pulley is special and is clutch activated like an A/C system is. So...that would mean the ECU is controlling it, probably kicking it off for better mpg when its not needed.
The companies also have "kits" which have pulleys and ECU upgrades in them. Just stand alone pulleys seem to be adding 15-30 hp while the kits with ECU upgrades add more like 50 hp.
I know I'm looking to add 50 hp if I can.
Old Apr 28, 2006 | 04:40 PM
Eracer76,
15-30 would be fine for now who sells it? In your research what have you found out about effecting the factory warranty?
Thank you
Pete
Old Apr 28, 2006 | 11:11 PM
Eracer76's Avatar
Originally Posted by petez Racing
Eracer76,
Thank you
Pete
RENNtech, Kleeman, ASP, Evosport are some that I've found. Just google them and they come right up.
Old May 14, 2006 | 12:30 AM
sg3054's Avatar
i changed to renntech pulleys and had them reprogram the computer. adds 45 hp. call bob brady at renntech. sg3054
Old May 14, 2006 | 12:37 AM
sg3054's Avatar
Maybe I'll have to take the chance and be the first one to spend the $2,850 or so that the pulleys/ECU upgrade kits cost.
i have installed the renntech upgrades, adds 45 hp. $3,000 price, done in 9/05. i was the first. sg3054
Old May 14, 2006 | 08:50 PM
Eracer76's Avatar
Default Re: '05 SRT boost level? Need more boost!!
SG...thanks for the info!
How do you like it? Do you think it was worth the $3k?
I know they claim 45 hp or so, but Im wondering, did you actually dyno your car before and after to verify its a true 45 hp?
Im coming from a dyno proven 400 hp SRT-4 that I just sold, and Im looking to add some hp to my new SRT-6, but before I spend the 3k it would be nice to hear from others saying its well worth it.
Im going to start making phone calls this week about getting a pulley/reprogram kit...I still need to decide on a company to go with, Renntech's website says $3,495 last time I checked, but if its really 3k I may have to go with them instead of the others.
Thanks for any more info you could provide!
Old May 15, 2006 | 05:06 AM
sg3054's Avatar
call me about renntech. 217-823-0709.
Old May 15, 2006 | 11:55 AM
Bullseye's Avatar
Eracer,
Check out evosport, they are a bit cheaper and always dyno the highest. Stage 1 ($2,890) dynoed at 340 rwhp and stage 2 ($5,490) dynoed at 375 whp.
Stage 1 in a C32 runs high-mid 12's@109-110 ish, Stage 2 runs low-mid 12's@112 ish. Also keep in mind the SRT-6 is about 300 lbs lighter than the C32.
Old May 16, 2006 | 06:51 PM
Evosport is also the only one with a solid (read no harmonic balancer) pulley. There have been some reported issues with evosport pulley's. The thread's have been deleted from mbworld.org.
RENNtech will deliver on their promises. They are conservative in their quoted figures.
The Kleeman & RENNtech pulley are the same.
wootto
U.K.
Aug 16, 2020 07:55 PM
4drturbo
Jan 3, 2019 02:46 PM
waldig
Jul 30, 2015 07:39 PM
xzmilan
Jul 22, 2015 10:40 AM
Tp'sfury
Jul 17, 2015 01:15 PM
