shakes when cold
Old May 21, 2006 | 01:18 PM
05blacksrt6's Avatar
Default shakes when cold
ok after my srt6 set for a little bit and i start it up for like 5-10 secs the car shakes almost like its misfiring, it only has 150 miles on it like i just got it lest then a week ago is this normal do other peoples do this, and do the all idle at like 300 rpms were that little line is on the tac?
Old May 21, 2006 | 02:01 PM
intenseblu's Avatar
Default Re: shakes when cold
it does have a very slight misfire kind of shake at idle for me as well... the 90 degree v6 has this inherently, the balance shafts help minimize the shake, but cannot completely take it away... change the oil if you haven't yet, bet that car sat on the lot for months and months like all of ours did 0w-40 mobil one synthetic only... remember...
Old May 21, 2006 | 07:08 PM
srtbeem's Avatar
Mine shakes a little also. It's inherent in the motor. At idle the supercharger is not engaged and the compression is 9 to 1. At high rpm you will be hard pressed to find a smoother motor. It's amazingly smooth.
Nov 11, 2015 05:22 AM
Blackktieguy
21
Oct 26, 2015 12:32 AM
jimf
Oct 10, 2015 10:22 AM
Idrenak
Sep 19, 2015 08:17 PM
tritongreen
Sep 18, 2015 07:32 AM
