Someone on XF has a 'particularly strong' C32/SRT-6 Motor. [Dyno - SI Stage I]
Old Feb 10, 2007 | 07:59 PM
  #61 (permalink)
Maxwell's Avatar
Default Re: Someone on XF has a 'particularly strong' C32/SRT-6 Motor. [Dyno - SI Stage I]
Originally Posted by srt6_crossfire
Yep... getting coilovers next saturday...
Once I'm happy with the traction, I'll hit Irwindale... put some of the doubts at MBWORLD to rest. :-)
how much do you want for your stock parts after you install the coilovers?
Old Feb 10, 2007 | 09:21 PM
  #62 (permalink)
HDDP's Avatar
Originally Posted by Maxwell
I'm not sure a thicker gasket would be worth the effort after you pull the heads. You might as well drop in low compression slugs in the block, that is if you calculate all that time you will spend tearing apart and re-installing the heads and accessories on zee motor take that sucker down to 8.5:1.
All good and well if they built lower compression pistons for the engine...
Anyways, how will shcrick's cams help the AMG motor breath better under pressure??? They might make more power on a N/A engine but not a boosted motor. Do they have specs listed on the AMG cams vs their cams?
I posted the specs on Schrick Cams on the forum. If my memory serves me, the lift is about 8% more.
Old Feb 10, 2007 | 11:58 PM
  #63 (permalink)
feets's Avatar
Anyways, how will schick's cams help the AMG motor breath better under pressure??? They might make more power on a N/A engine but not a boosted motor. Do they have specs listed on the AMG cams vs their cams?
As an amateur engine builder I'd like to step in here if I may. I've spec'd out cams before and even created the custom grind bump stick in my twin turbocharged 440.
Let me break a motor down into simple parts to allow non-gearheads to understand things a little better.
The throttle body and intake manifold are like the mouth. They let the air get into the motor. A bigger mouth can draw air easier than a smaller mouth. Opening the mouth too wide does nothing for you. You can't run down the street any faster with your mouth wide open, right?
The cylinder heads are like the lungs. They separate that mouth full of air into useable portions and direct it as efficiently as possible to the place where the work is done. You can run faster with a set of healthy lungs than you can with lungs full of tuberculosis.
The pistons are like the muscles. They push the bottom end around and make it go. If your muscles fail, you fall down and go boom. If your pistons fail, motor go boom. Wallet go boom. You fall down go boom. Wife go boom up side your head. Boom again. Boom. Boom. Boom.
The crank is like the legs. It turns and makes things go. The crank spins the flywheel and/or torque converter and connects the power to the rest of the drivetrain.
The cam (or cams in our case) is like the brain. Without it, nothing else matters. It tells the heads (lungs) when to take that air in and when to let it out. It also tells the heads how much air to let in and out. That's where the witchcraft comes in.
A successful cam relies on several major measurements and they all must work together. Those lumpy lobes sticking out all over the cam are incredibly intricate.
Lift: this determines how far the valve opens and therefore how much air gets into and out of the cylinders.
Duration: this determines how long the valve is open.
Overlap: this tells you how long both the intake and exhaust valves are open at the same time.
Lobe separation angle: this tells you how long both valves are closed so the ignition can take place and the piston can make power.
Cam centerline: this tells you how to physically align the cam with the crankshaft for optimum performance. It sets the timing of the whole cam.
Designers have to take all this stuff and mash it into something that's going to work with the rest of the combination. Stuffing a HUGE cam into an everyday motor isn't going to make anybody happy. It won't match the heads, intake, compression, or rest of the car. That's one of the most common mistakes made by hot rodders.
The engineers have to tell the cam when to open the intake valve, how high it should be held open, and when to close it. That's got to be matched with how much air the throttle/intake/head combo can flow and timed perfectly to the piston movement.
Next, they've got to tell it how long to keep both valves closed so the spark can burn the fuel and let the exploding gasses shove the piston down the hole.
Then, the designers have to figure the optimum time to open the exhaust valve as well as how high it needs to be and when to close it. This is critical to get all the burned nasty stuff out so the engine can have a fresh breath that isn't contaminated with exhaust.
Generally, before the exhaust valve is fully closed, the intake starts to open again. This is known as overlap. The air in the cylinder is already rushing out the exhaust valve and isn't likely to change direction. Opening the intake a wee bit early gives it a head start so it can be open further when the piston begins to move down. That means the vacuum created by the moving piston has a better chance at drawing more air.
At 6,000 rpm, each valve is opening 50 times per second. That means the valve is thrown open nearly 1/2 inch and slammed closed in less than .02 of a second. That's fast. Ugly fast. Don't get your finger caught in there. Every valve cycles a dozen times in the blink of an eye. Literally.
A naturally aspirated engine, supercharged engine, and turbocharged engine will all have different preferences.
The N/A motor needs a balanced cam because it relies on atmospheric pressure to push air into the motor.
A crankshaft driven supercharger will respond better to a similar cam but doesn't need to worry as much about the overlap. It's cramming air in faster than the engine can take it. Hanging the exhaust valve open while the intake is opening will let the blower shove the bad air out so you get an even cleaner burn.
An exhaust driven turbocharger is the exact opposite. The exhaust being pushed out of the engine drives the turbo. It's kinda like a whiffle ball stuffed in the exhaust pipe. It slows down the exhaust flow and creates pressure in the exhaust manifold. That same pressure is the glorious force that spins the turbo and shoves air into the engine faster than it can breathe on it's own. That's the same kind of pressure the supercharger makes. That exhaust system pressure is what separates a turbo from a blower. In all but the most extreme engines, the exhaust pressure will be higher than the intake "boost" pressure. If the cam holds both valves open at the same time, that nasty exhaust pressure will prevent the exhaust from getting out and pollutes the clean intake air. There's a fine balance between closing the exhaust and opening the intake. You still want that head start on the good stuff but don't want the bad stuff hanging around any longer than possible.
Quite often, a stock style cam will favor a turbo over a blower. The same ideas that reduce emissions (low overlap) work in the turbo's favor. The blower's extra little benefit of shoving the bad air out is minimized. The low overlap also makes the engine more efficient at low rpm. They idle smooth and quietly. When the overlap starts to get big, the engine is not happy running slowly. The dirty air isn't moving fast enough to get out and contaminates the intake charge. The result is a lumpy bumpy idle that makes a hot rod sound all mean and pissed off.
What this all comes down to is that you can open a valve the same distance with two different cams but when and how long it happens will make all the difference in the world. You can really go off the deep end and even look at how quickly you open/close the valve. Think back to high school algebra when you had to calculate the area under the curve. More area means more air flow.
You can compare it to a dyno chart too. Peak power is useless if there's not a big fat curve on each side, right?
Voodoo, witchcraft, black magic, Physics and the Land of Geekdom, whatever you want to call it, there's a lot more to cams than the numbers you see on paper.
Clear as mud?
Old Feb 11, 2007 | 06:01 AM
  #64 (permalink)
MMZ_TimeLord's Avatar
Feets,
That was one of the BEST ever explanations of engine operation, optimization and function I've ever had the pleasure to read.
Thank you sir.
Old Feb 11, 2007 | 10:10 AM
  #65 (permalink)
feets's Avatar
Whaddya smokin? That was one of my famous late night rambles. It's amazing that it made any sense the next morning.
Should I go back and create Cliff Notes?
Old Feb 11, 2007 | 10:26 AM
  #66 (permalink)
VQ35DE's Avatar
I thought it was cool also.
Old Feb 11, 2007 | 11:48 AM
  #67 (permalink)
The Toy's Avatar
I also thought it was very well explained. Feel free to add any cliff notes if you have them. Nice write up!!!
Old Feb 11, 2007 | 03:29 PM
  #68 (permalink)
Maxwell's Avatar
so basically adding 8% lift to the stock cams on a pressurized motor will not yield anymore power, correct?
Old Feb 11, 2007 | 03:46 PM
  #69 (permalink)
feets's Avatar
Now the physics beast rears it's ugly head.
8% lift is negligible. In essence, it does nothing.
HOWEVER
How quickly they open the valve and how long they hold it open has a LOT more effect than how high they lift it. How long the valves are open at the same time can also move the power peak higher or lower in the rpm range.
If the stock cam opens kinda lazy and holds .300" lift for 180 degrees of duration and the new cam holds .300" lift for 200 degrees of duration, the new cam will usually make more power if the peak lift is within 10% and overlap is not seriously altered.
With modern overhead cams and roller valve train, engineers are really getting some wild rates of lift and extended duration out of cams. Factory guys have to keep the emissions police and warranty bean counters at bay while the aftermarket guys can spend the time and money to make a more radical piece.
There comes a point where you can't lift the valve any higher because the spring hits coil bind and becomes a solid mass, valves get dangerously close to pistons, and simple geometry issues cause the lifter to begin rolling too far across the head of the valve. Any of these issues can lead to catastrophic engine failure. Before you hit any of those points, you start to look at duration. Spread that lobe out and make that sucker big and fat. That will let more air in over a longer period of time than just poking it a wee bit higher.
If you offered me a cam with 8% more lift with all other factors being the same, I'd laugh in your face.
If you offered me a cam with 8% more lift but with more duration where it counts and timed better to my application, I'd have the tool box open in a heart beat.
Looking at the lift alone is like telling a single man about a well endowed woman. A large bust can usually be found on a 600 pounder. What else is tagging along for the ride, yanno?
Old Feb 11, 2007 | 03:50 PM
  #70 (permalink)
HDDP's Avatar
Here's the Schick Cams specs... I posted the OEM specs on the forum somewhere... Lift at lobe, Duration, etc... I don't think the poster was saying that the Schrick Cams were useless, I think he didn't have the information to see the difference between the OEM spec and Schrick performance cams and wanted to SCHOOL us as to what cams do and how they effect HP of a car... He did a good job of doing that...
If you want to see dyno results from Schrick Cams on this type of application, go to Turner Motor Sports website...
Old Feb 11, 2007 | 03:59 PM
  #71 (permalink)
HDDP's Avatar
I can't find the final VTS but here is the original that we created for SCCA... you can compare the OEM spec to Schrick spec...
File Type: doc
Old Feb 11, 2007 | 04:08 PM
  #72 (permalink)
feets's Avatar
Maybe this will help...
Look at these two camshafts. See the sharp pointed lobes on the first one? Imagine it having 8% more lift than the second one with it's big fat lobes. Can you see that the wide lobes of the second cam will hold the valve open longer?
Who cares about a tiny bit mroe lift when you've got that much more area under the curve?
Oopsie! I didn't see Derek's posts. I was just hoping a visual would help.
Old Feb 11, 2007 | 04:14 PM
  #73 (permalink)
HDDP's Avatar
No problem Feets... Take a look at the specs... and then tell me that the Schrick cams are not better than the OEM... In my original post I meant lift & duration... Even though... They will only create an additional 7-10 hp for this engine... I gave you all the information at your finger tips... Do the comparison...
http://www.turnermotorsport.com/html/index.asp
Old Feb 11, 2007 | 07:05 PM
  #74 (permalink)
feets's Avatar
For some reason, the document wouldn't open for me.
I have little doubt that an aftermarket cam would offer more power than a stocker. You've got a pretty good handle on engines by what I can tell. I bet I couldn't tell you anything about the cam that you didn't already know.
Old Feb 11, 2007 | 11:16 PM
  #75 (permalink)
HDDP's Avatar
Here's the specs I have on the OEM cams and also the Schrick cams. Perhaps you can verify my original calculations... I'm not always correct... Sometimes I need somebody to double check me...
Old Feb 11, 2007 | 11:34 PM
  #76 (permalink)
x'ed's Avatar
side note...i'm really excited to see yours and srt-6's cars on the track, one race prepped machine and one street legal lethal weapon.
Old Feb 12, 2007 | 09:51 PM
  #77 (permalink)
feets's Avatar
The first item posted doesn't tell me anything except lift. It's fairly useless for a cam comparison.
The second item is a red X.
Old Feb 16, 2007 | 02:11 PM
  #78 (permalink)
msheredy's Avatar
Thanks for the vids... check your PM too.
Can you post those videos on youtube? I'd like to see this thing run!!!
- Matt
Old Feb 16, 2007 | 02:54 PM
  #79 (permalink)
JP@SI's Avatar
- Matt
They are on youtube. Search: SpeedInnovation
JP@SI
Old Feb 16, 2007 | 04:57 PM
  #80 (permalink)
srt6_crossfire's Avatar
Originally Posted by SRT SIX
srt6_crossfire,
I am in Rancho Cucamonga and would like to arrange for a base dyno at SI. Do you know what they charge for just that?
Do you still have plans to dyno yours? I'm curious to see what your base #s would be on the same dyno.
