Lurch
Old Aug 3, 2007 | 01:33 AM
cgocifer's Avatar
Default Lurch
Not sure if this has been posted before, but here goes:
From a stop, about 2 seconds after I begin moving, the tranny (or something) causes a slight lurch. With the windows down, I can hear a very quick and faint squeak or his (like a mouse). The tranny is perfect all other times. Just when leaving from a stop. Any clue what this could be?
Old Aug 3, 2007 | 10:08 AM
simon-srt6's Avatar
Default Re: Lurch
If it is at 2,900 rpm it could be the supercharger clutch engaging. This could be an indication that it needs replacing as you shouldn't feel a lurch either it should be smooth. The only time I have felt it engage is if I put it in 1st gear and accelerate very slowly and as you get to 2,900 rpm you feel a short "drag" on the engine as the supercharger engages. If you accelerate normally it is so smooth you feel nothing.
Old Aug 3, 2007 | 11:01 AM
AMGLover's Avatar
Default Re: Lurch
Message Deleted
Old Aug 3, 2007 | 12:10 PM
cgocifer's Avatar
Default Re: Lurch
The mileage is nearly 11,000. If I accelerate quickly, it is less noticeable. When I accelerate slowly (let off the brake, slowly roll on the throttle) that is when I feel it. This happens only from a standing start. Yes, it kinda feels like a slight drag on the engine more than it feels like a lurch. This is the only SRT (or xfire for that matter) I've ever driven, so I'm not sure if I'm over analyzing.
Old Aug 3, 2007 | 02:09 PM
AMGLover's Avatar
Default Re: Lurch
Message Deleted
Old Aug 3, 2007 | 02:51 PM
cgocifer's Avatar
Default Re: Lurch
Will check. It doesn't really feel like the tranny is slipping, it feels like a quick drag, then all is fine.
Old Aug 3, 2007 | 05:24 PM
cgocifer's Avatar
Default Re: Lurch
Well, I did the throttle reset procedure. Seems to have worked to some degree. It happens less frequently. I also checked for leaks. None to be found. I think I'm just not used to the automatic. I've never owned an automatic. NEVER!
Old Aug 3, 2007 | 05:32 PM
AMGLover's Avatar
Default Re: Lurch
Message Deleted
Old Aug 3, 2007 | 09:24 PM
cgocifer's Avatar
Default Re: Lurch
Yep, figured that one out too. I had no idea what the W meant. What a jackass! I guess I need to read the manual a little bit.
Old Aug 6, 2007 | 11:53 AM
cgocifer's Avatar
Default Re: Lurch
Ok, so, the lurch continues. I've determined that it isn't the transmission. I put it in manual shift mode and again, it only happens when leaving from a complete stop. When accelerating slowly, at around 2500 rpms, regardless of gear, it feels and sounds almost like an AC compressor kicking on, putting a lag on the engine. It definitely sounds and feels like a load is being put on the engine. Yes, the AC was off. Accelerating quickly, this is pretty much non-existent.
"If it is at 2,900 rpm it could be the supercharger clutch engaging. This could be an indication that it needs replacing as you shouldn't feel a lurch either it should be smooth. The only time I have felt it engage is if I put it in 1st gear and accelerate very slowly and as you get to 2,900 rpm you feel a short "drag" on the engine as the supercharger engages. If you accelerate normally it is so smooth you feel nothing."
This sounds very much like what I am experiencing. Does this mean the SC clutch needs to be replaced or do others experience this?
Old Aug 6, 2007 | 01:42 PM
AMGLover's Avatar
Default Re: Lurch
Message Deleted
Old Aug 6, 2007 | 02:17 PM
cgocifer's Avatar
Default Re: Lurch
Originally Posted by AMGLover
First see if you can get them to download any codes. When you are in first and accelerate to 2,500 you are still in first...correct?! Then try it in W mode since it starts you in second from a dead stop. If you accelerate slowly from a stop and get to 2,500 rpm the SC might never engage...or should not. The SC does draws 60 hp from the engine so if it were engaging at the wrong time it would cause a BIG lag! That said it would not be a clutch issue but an ECU issue. Have them do:
TBS: 25-Aug-06 - 08-030-06A - Engine Control - PCM Initialization Procedure
See if that helps.
Thanks. Happens mostly in 2nd gear around 2,500 rpm. It does it in W mode as well. Pretty sure it is the SC engaging, but I think it should be smoother and not make the chirp sound. SC clutch problem maybe. I'm taking it in on Wednesday. I'll definitely mention the TSB you mentioned as well as the condensation in the headlights issue.
Old Aug 6, 2007 | 03:23 PM
msheredy's Avatar
Default Re: Lurch
Originally Posted by simon-srt6
...it could be the supercharger clutch engaging...
This is correct. Several MB C32/SLK32 as well as C55 owners have experienced this. The squeak is indeed the clutch on the blower. My SRT does this as well.
If these intercooler systems weren't so problematic it would be nice if we could do away with that clutch altogether.
The attached screen shot is from C32life where they say you can tighten the clutch assembly. I haven't done this yet.
File Type: png
Old Aug 6, 2007 | 03:39 PM
cgocifer's Avatar
Default Re: Lurch
Well, seems to be common, but it doesn't mean that it's normal. Are you just living with the problem, or are you going to take it to the dealer so they can replace the supercharger over a 2 to 3 week period?
Old Aug 6, 2007 | 05:28 PM
msheredy's Avatar
Default Re: Lurch
What other cars out there utilize an electromagnetic clutch on a supercharger? I can't think of any off hand. This being the case I'm open to think that this is indeed normal. Plus I don't expect a clutch to engage seamlessly 100% of the time. Just think when you turn on your AC...
It's going to be damn near impossible to convince the dealer that there is a problem when we took another SRT out to see if it did the same thing... it did.
Old Aug 6, 2007 | 06:04 PM
cgocifer's Avatar
Default Re: Lurch
Nope, never had a car with an electromagnetic supercharger clutch. I just read a bunch of horror stories about superchargers being replaced due to SC clutch problems.
Ok, I think I'll just drive it until something really goes wrong with it. No sense in over analyzing anything. I feel better knowing that other cars on here are doing the same thing. Thanks!
Old Aug 6, 2007 | 06:28 PM
AMGLover's Avatar
Default Re: Lurch
Message Deleted
Old Aug 6, 2007 | 08:40 PM
cgocifer's Avatar
Default Re: Lurch
Thought this was an interesting solution to the chirp sound. This is from a MB forum dealing with E55 AMG blowers. They use similar electromagnetic S/C clutches.
http://forums.mbworld.org/forums/sho...threadid=68342
Playdrv4me
Dec 6, 2012 07:41 PM
Rokypoky
Aug 21, 2009 11:23 PM
Playdrv4me
Aug 19, 2009 09:48 PM
Hangman
Sep 26, 2008 07:13 AM
Sharonaln67
Jan 8, 2007 08:24 AM
