New Top Speed In SRT 6
Old Sep 4, 2007 | 02:26 PM
RPM's Avatar
RPM
Moderator
Default Re: New Top Speed In SRT 6
Originally Posted by DamnRock
How is it possible... I thought these were computer limited at 160? I took mine up to 160 and it seemed to pull really hard right up to it but stopped pulling at 160... did I just not wait long enough or do you guys have something removing the computer limit?
Rock
Steve has the Renntech kit on his SRT6 = no top speed limiter.
Old Sep 4, 2007 | 04:19 PM
Steve Hellums's Avatar
Originally Posted by msheredy
I'm looking into the MSD Dash hawk. It records 0-60 plus quarter mile times. The best part is the parameters that this thing can monitor. I just have to get under the dash and make sure it is CAN compliant. I believe it is around $300 bucks.
I've been looking into the G-TECH meters off & on this morning. Reading how they work, about their accuracy and where to get one the cheapest. So far E-Bay looks like the cheapest place to get one, (two different model's) the SS and the RR. The SS is the cheapest, $199 on most web. site's $299 for the RR. You can get an SS delivered off E-Bay for around $185, or I'm looking at an RR a guy's got up NIB never been used, starting bid $120. I'm going to see if I can get it for cheap, if not I'll just go a head and buy a new SS model.
Old Sep 5, 2007 | 09:49 AM
Alright, did someone on here dog me on this meter? I opened the listing this morning and the bidding ended early, seller closed it.
Old Sep 5, 2007 | 10:05 AM
ShawnQ's Avatar
Steve,
Wasn't me!
And, to answer your previous question about which one is good and where to buy - I can't help ya there as I've never purchased one. I just know several of the guys on my Mustang forums use them for somewhat accurate baseline numbers, and then numbers after modifications. It's not a dyno, but it is relatively close, and much more convenient.
They have all sorts of features - which I'm sure you've been reading about.
Ebay would be my first stop also!
SQ
Old Sep 5, 2007 | 11:20 AM
Originally Posted by ShawnQ
Steve,
Wasn't me!
SQ
It's kind of weird that some E-Bay store's items are higher than their web site's and some are cheaper. I done an ask a seller question on an RR model this morning, they come with the software and cable's to connect up to your PC so a guy could post up results of his run's. The RR is around $40 to $60 more than the SS, witch would probably be worth it. I should have e-mailed the guy with the one that ended early yesterday, I probably would have saved myself around $100 or so.
Old Dec 24, 2007 | 02:34 PM
240M3SRT's Avatar
Holy hell...180mph!
Dunno if i missed this thread or what but heres a bump for what these cars are capable of for anyone else new to the forum.
I guess ill go ahead and add my contribution. I hit 158pmh the other day. Not that im condoning any one else to do any top end pulls.
Time for some mods!
Old Dec 24, 2007 | 02:53 PM
MMZ_TimeLord's Avatar
Always try to get to a 'closed' track or a known place to do these kinds of speeds (old air strips, etc.)
That being said I've only pulled 140 once and that was on a long straight slight down grade with about 10 mile visibility and no off ramps for 20 miles.
I felt I had to pace the SL55 that blew past me...
Old Dec 24, 2007 | 03:06 PM
Maxwell's Avatar
put me down for 145mph at El Mirage Dry Lake.
Old Dec 24, 2007 | 07:50 PM
huudoo's Avatar
WOW ! now that is something what did that kit cost
Old Dec 25, 2007 | 01:04 PM
cruzinquick's Avatar
At least you have country roads, here in AZ they just use the freeway. Check this local guy out with one of his many cars. He even has a bugatti veyron on order for Jun. 08. He has to be a speed junkie, like most of us. You can hear him say he's doing 170 on a turn. It's was all over the news, not sure if he was even arrested. He own's **** site called ftvgirls. So I'm sure the he's pretty lawyered up.
http://ca.youtube.com/watch?v=6IWXgdxWqFw
Old Dec 25, 2007 | 01:34 PM
Maxwell's Avatar
are you sure you can hit 180mph in the srt6? not saying it doesn't have the Horsepower to do it, but wouldn't you hit the rev limiter in 5th gear long before you make 180mph?
I will have to look at the gear ratios on the auto and final drive ratio, assuming you bumped your rev limiter to 7000rpm. I'll let you know what top speed is really limited too. later!
Old Dec 25, 2007 | 07:11 PM
apkano's Avatar
Life is random...so am I.
Impressive video.....I especially like the outside clip at the 3:52 mark! WOW!
Old Dec 26, 2007 | 03:24 AM
I have no electronic speed cut out,(Renntech Kit). The speedometer read 180 MPH, but with the factor of the 285's added in, witch add's 2 MPH for every 60 MPH the real speed would have been 186 MPH and my tach was reading 5,800 or just a hair over. If I remember correctly Renntech said my new rev limiter was at 6,200 RPM.
Old Dec 26, 2007 | 04:22 AM
chuck65's Avatar
Steve,
We live in Ohio but have a place on a lake in NE Indiana near Angola. Can't imagine going that fast anywhere near there because of the hills and curves. What part of Indiana are you from? And No, I,m not a cop looking for your "hill".
Old Dec 26, 2007 | 06:29 AM
Originally Posted by chuck65
Steve,
I live in what is called south central IN, but I'm closer to the west side. If you look on an Indiana map, find Bloomington & Vinennes then draw a line connecting the two, I'm about right in the middle (BOONIES). There is a lot of flat farm land where I'm from and the place I opened it up to that speed is about a 2 &1/2 to 3 mile straight away with a sweeping 90 degree turn at the end of it. Before you get to this straight stretch you are on a hill and can see for miles to make sure there is no other traffic on the road so I'm not putting anybody in danger but me. I had opened up my 04 coupe from the top of the hill and I could only get it up to 148 MPH before I had to back out of it for the curve. When I done the 186 MPH in the SRT 6, I was way past the bottom of the hill when I decided open it up from about 65 MPH, it probably didn't take 2 mile's to reach that speed and still get slowed down for the curve.
Old Feb 23, 2008 | 05:39 PM
BrianBrave's Avatar
<--- Huge Horsepower
You still own the record Steve.
I took my SRT to stretch of road out in the desert by Mojave airport. A nice flat 4 mile road.
There is a big bicycle race going on down by the coast (Amgen tour of California - (The Company I work for sponsers the #2 team in the world -- "Team CSC")
Anyway - I knew that the race would take almost all the available Highway Patrol Officers to run this huge race thru the area so I figured it's a good day for a high speed run if I went out to the desert.
Conditions: Flat, two lane road - blacktop - in excellent condition - (no place for a CHP to hide)
I dialed Mohave Airport AWOS prior to the run -
Temp: 10.2 Deg C - - 50.4 deg F
Dew Point: 0.3 Deg C - - 32.5 deg F
Relative Humidity: 53%
Skies: OVC 080
Altimeter: 30.04 in mercury
Corrected elevation 2,358 feet ASL
Run one = 165MPH
Run two = 170MPH
It felt like the SRT could do more but I needed time to reach top speed and road was running out. But at least now I know that SpeedInnovation raised my speed limiter.
I forgot my camera at home (about a 1 1/2 drive) but didn't think I could take pictures at that speed - guess what - this car is rock solid and I could have steered the car with one hand and snapped a pictures with the other - next time I promise to remember the camera and perhaps some spotters with a camcorder....
Old Feb 23, 2008 | 08:57 PM
sonoronos's Avatar
I know a few people may think I'm crazy, but there's a nice 2 and a half to 3 mile stretch of road I take to breakfast early Sunday mornings, you are coming down off a hill and can see for miles.
I just spent a day recruiting at Iowa State and after driving those roads, I don't think you're crazy at all. Farmland on all sides, four-lane divided highway, visibility for miles, and no exits and entrances. Pedal to the metal. The biggest danger is hitting a deer.
Old Feb 24, 2008 | 04:25 AM
  #38 (permalink)
Coyote's Avatar
Sonoronos, at that speed, I don't think you or the Deer would ever notice
the impact. Not even sure if you'd have a chance to see the deer and get
your adrenaline pumping before impact. I'm pretty sure it would be an
immediate lights out for both you and the Deer. So, be careful out there,
and go hunting regularly to thin out the Deer population.
Coyote (smacking my lips at the thought of tasty venison).
Old Feb 24, 2008 | 05:03 AM
  #39 (permalink)
That stretch of road is only two lanes, but there are no other roads that join's into it in that particular area. It use to be a natural water fowl wet lands, back in the early 70's they built levie's, put in drainage and made it one of the biggest farms in southern Indiana. I have never seen a deer on this stretch of road, but have seen a few big birds. About two years ago they started converting it back into a natural wet lands again, it's all low and flat and you can see for mile's in all directions. My biggest fear of opening it up on this stretch of road is Mr. policeman .
Old Feb 24, 2008 | 03:51 PM
  #40 (permalink)
Goldwing's Avatar
Deer are the one thing that really scare me at high speed. I was coming down M66 (middle of no where, north of Grand Rapids, east of Muskegon, west of Midland) doing 95-100 in my roadster at dusk. Coming around a long curve I saw eyeball reflections and then zipped past 3-4 deer on the side of the road. Balance of the 80 mile trip home was at 55-60.
