Disconnecting Battery
Old Oct 10, 2007 | 12:32 AM
simon-srt6's Avatar
Default Disconnecting Battery
if I disconnect the battery, will I need a radio code ? or will everything be just fine and work first time.
Old Oct 10, 2007 | 02:24 AM
crossfirefun's Avatar
Default Re: Disconnecting Battery
Not sure on the radio but it will reset your computer which could have a problem with an emissions test if it is required in your area.
Old Oct 10, 2007 | 04:16 AM
simon-srt6's Avatar
Cheers, how will the emissions be affected by disconnecting the battery ? I thought the Lambda sensors adjusted mixture from analyzing the exhaust to fit a "map" / "profile" ?
The reason I was asking as I was told to fit a sprint booster, I need to disconnect the battery or it won't work. I am fitting it tonight so am I a bit concerned now that the car won't work after unless I do this and if I do, the emissions could be out and if that is the case it could be causing engine damage (depending on how far out it is).
Old Oct 10, 2007 | 05:39 AM
xfire2005's Avatar
I installed my sprint booster without disconnecting my battery. I did do the throttle reset afterward to feel the difference completely from the start.
I have a MT and it takes a bit of getting use to it due to the much faster throttle response. Once I acclimated myself to it, I don't know how I drove without before.
if you disconnect the battery (which you do NOT have to do) your ECU will reset, no codes, and you will have to re-program the stations on your radio. That's it!
Enjoy it, and as someone said earlier - Drive it like you stole it!!
Old Oct 10, 2007 | 06:06 AM
simon-srt6's Avatar
Thank you, I was worried as one post I read said it didn't work until they disconnected the battery for 2 mins.
blackpepper
Oct 4, 2017 06:09 AM
o55ie18
Oct 5, 2015 05:50 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
tritongreen
Sep 18, 2015 07:32 AM
Valk
Sep 17, 2015 11:43 AM
