high flow intercooler pumps
Old Nov 2, 2007 | 04:20 PM
LantanaTX's Avatar
Default high flow intercooler pumps
Came across this about using Ford itercooler pumps and thought you guys might be interested in case you haven't already seen this:
http://mbworld.org/forums/showthread...ight=lightning
Old Nov 2, 2007 | 04:40 PM
HDDP's Avatar
Default Re: high flow intercooler pumps
This is my choice and I'm sticking to it #10-24504-03
Old Nov 3, 2007 | 07:12 PM
svo's Avatar
svo
Any Engineers or guys good at Thermal Dynamics to do the math and find out what's the most volume we can push through the heat exchanger before loosing cooling efficiency?
And in simple terms - if the coolant goes through the system too fast it doesn't have time to cool down, so if the pump flows too much we'd be running nothing but hot coolant.
Old Nov 3, 2007 | 08:09 PM
BrianBrave's Avatar
<--- Huge Horsepower
Very true for us "street folks"
But HDDP will have a Dry Ice cooling tank and a larger HE. The greater the volume the better. (so it seems)
I am not a thermal dynamics engineer so I plan to install a IAT guage.
If my IAT's rise when I install a ODPS then I will upgrade to the Johnson Pump and seperate the engine/HE coolant tank.
Old Nov 4, 2007 | 05:54 AM
HDDP's Avatar
Gerhard Shriff (Bell Intercoolers) did the calculations for the SRT6 engine and came-up with a 7gal. per min. flow rate to maintain a 400hp output. That's why we decided on that specific Johnson pump #10-24540-03... Granted, you will have to increase the OEM tube diameter from 5/8" OD to 3/4" OD, but it's really an easy job...
Old Nov 5, 2007 | 03:58 AM
Steve Hellums's Avatar
I have the same problem with my 64.5 Mustang. I put 3:55 gears in the pumpkin and at highway speeds I've been have trouble with it getting hot ever since, it's running around 2,950 RPM @ 60 MPH. I finally figured out that it's just pumping the coolant through the radiator so fast it don't have time to cool. I just ordered a complete 3:25 posi unit for it last week. I wanted 3:40 gears when I changed them out a few years ago, but was having trouble finding them and just setteled for the 3:55's.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Billy22Bob
Sep 28, 2015 08:08 PM
Sep 28, 2015 07:40 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
