SL55 "Y" & hose install w/pic's & results
Old Nov 19, 2007 | 08:04 AM
Steve Hellums's Avatar
Thumbs up SL55 "Y" & hose install w/pic's & results
I done my install this weekend, to keep any possible restrictions down this is what I used. 2 ea 2.75 ID semi-truck radiator hose's 40mm long & 2 ea 2.5 semi-truck radiator hose's just wide enough to fit the notch of the OEM air boxes. I also used 2-3/4 piece's of exhaust pipe inside the 2.75 hose's to keep them from collapsing when inserting them into the SL55 hose's. Since the SL55 hose's are oval the round hose's I was using did not want to fit correctly, so after getting them in the best I could I used a little hand held bar clamp to reshape them to the oval position. Then the 2.75 hose fit like a glove, I then put the hose clamps on & tightened them down snug. After that I used the clamp to make them round again. I ended up having to trim a little off the corner of the lower portion of the air box, it already had a notch there. I tried to do the install with one air box left on the car, installing the "Y" then the second air box, but the smaller hose's I'd put on the air boxes kept slipping out of the big hose's. Soooo, after getting things together the best I could on the car I pulled both air boxes with the "Y" & hose's all clamped together. I sat the whole thing on the bench to make adjustments and make sure the small peice's of hose's were in place good. I then tried to mount it back on the car but the big hose's were hitting the supercharger screw covers. So I pulled the whole thing back off and used the bar clamp to bend the large hose's that have the peice's of exhaust pipe in them for reinforcement to an oval shape. The gains I got on a G-Tech meter were .162 @ 3.16 mph in the 1/8th & .362 @ 3.76 mph in the 1/4, 0 to 60 4.316 to 4.110. The G-Tech will give you a HP & TQ readings also, it showed a gain of 27 hp & 19 tq from my best previous run, but these gain also include removing the resonator.
Old Nov 19, 2007 | 08:07 AM
Default Re: SL55 "Y" & hose install w/pic's & results
Some pic's of the G-Tech meter & a few others. These runs were done by just letting off the brake & flooring it with the TC on, anybody that has driven an SRT6 knows you can get a better launch by gradually flooring it. You can tell there were basiclly no differences in the 60' mark, so I do believe with some launch practicing I could break into the 11's on the G-Tech meter. The first 2 G-Tech pic's are before & the second two are after the install.
Old Nov 19, 2007 | 09:44 AM
ShawnQ's Avatar
Nice write up!
I am waiting on cool/dry air to get back to the drag to do a before/after on my SL55 Y-Pipe.
I still don't believe the dyno...but the track will tell for sure.
You need to get that car on a track!
Old Nov 19, 2007 | 10:18 AM
cruzinquick's Avatar
I agree that car needs to hit the track. Use the post I put with the track calculator to see what temp is the best for your track. It looks great and stock.
cruzinquick
Old Nov 19, 2007 | 10:49 AM
Originally Posted by ShawnQ
Nice write up!
I probably could have explained a little better, but it was getting kind of long. The next step is opening up the restrictions on the ends of the intake tube's in the radiator support. I'm going to make the ends of the intake tube's as big as possible and use some type of 45 & cut a bevel end on it so it's not straight foward, I couldn't believe all the bugs in my filters from the tube's being a straight shot through the grill. I thought about putting cone filters out front next to the grill and pulling the filters out of the air boxes, but the lower portion on the OEM air box & stock tubes are not truely sealed enough to do so. And yes I do need to get it to a track, it sucks living in the middle of nowhere sometimes.
Old Nov 19, 2007 | 12:05 PM
jonnyangel04's Avatar
If you take those tubes off you will loose 21 hp there is a dyno on MB world as for going larger even though more air is coming it is still going to be ristricted as soon as it hits the air filters. IF your looking to keep everything looking stock you should run the VRP air box AND sl set up thats the only way to see the gain your looking for unless of coarse you go the needswings route.
Old Nov 19, 2007 | 12:08 PM
BrianBrave's Avatar
<--- Huge Horsepower
The SLK32/C32 folks who have installed the SL55 V8 airbox use a dremmel and enlarge the openings at the radiator supprt (the SL55 intake tubes are larger then our stock ones) and attach the new intake tubes to the support with a fastener
Old Nov 19, 2007 | 12:21 PM
I'm not going to take the tube's off, I'm going to go back toward the motor from the radiator support to where they start to narrow. cut them off there and add a bigger tube of some type to go through the radiator support, even if I have to do some mod's to get it through. It's just my opinion, but I think I can deliever more air with 2 - 2.25" to 2.5" pipes than 1 - 3 inch pipe.
Old Nov 19, 2007 | 12:24 PM
Thanks Brian, I'll have to check that out. I had just planned on going to Auto Zone & looking at some of their intake fittings, they seem to stock quite a bit of intake tube's anymore.
Old Nov 19, 2007 | 12:26 PM
ShawnQ's Avatar
NeedsWings agreed with this - but, from what he said, the air that the single 3" is supplying is more than enough for the car - so basically the only advantage you will gain from the dual pipes is looks (which is what we are after, retain the somewhat stock appearance). The added air wont really benefit because it is more than the engine can use.
SQ
Old Nov 19, 2007 | 01:04 PM
SQ
I agree the engine can only take so much air. I don't know if you have noticed, but there is another "Y" under the throttle body I'm guessing where the supercharger delievers the air to the valve train. But who knows how much the supercharger can force through it. Just with doing the SL55 "Y" & hose's I can tell a difference in my exhaust sound under full throttle. It's like SSSSSHHHHHH!!!!!, sounds strange and hard to decribe.
Old Nov 19, 2007 | 01:25 PM
ShawnQ's Avatar
The Y beneath the intake is for the intercooler.
Take a look at HDDP's SRT Engine Transplant thread. He has some pics of his torn apart, and it helps to look at them if you are trying to see how it all works. It's a pretty in-efficient design, to be honest...but it is what it is.
SQ
Old Nov 19, 2007 | 04:04 PM
BrianBrave's Avatar
Here are some picture I took when I had the manifold intake pipe out to install the boost gauge
Old Nov 20, 2007 | 12:16 AM
simon-srt6's Avatar
Hi Steve,
You have done this slightly different to the way I am doing mne. I don't need to "Pad" the Airbox like you did with some pipe. I have fitted a 6mm wall hose inside the SL55 pipe and it fits straight onto the airbox. Also I have used a Stainless Steell ring to clamp onto to fit the 2 pipes together.
What you have done looks really neat too. Good to hear the performance and sound improvement too. Can't wait to actually fit mine at the weekend, weather permitting. I thought I was going to be the first with this mod, but the weather let me down and you beat me to it. Well done.
Si
Old Nov 20, 2007 | 03:01 AM
Originally Posted by simon-srt6
Hi Steve,
Si
I pulled out my grill last night to check out what size hole the end of the intake tube's fit into. They are oval shaped measuring about 2" tall & 1" wide. I knew they were small because I had noticed them when I had my grill out last winter, but I didn't relize they were that small. They equal out to about an 1-1/2" to 1-3/4" ID round hole. I was going to wait till this winter to make improvements there, but I think I'm going to go ahead and do it this weekend. I hope the gains are as good as the SL55 "Y" & hose's.
Old Nov 20, 2007 | 06:23 AM
ShawnQ's Avatar
Steve,
Let us know how you end up increasing the intake size...that seems like a big bottleneck at this point.
SQ
Old Nov 20, 2007 | 06:37 AM
ws6vert's Avatar
Yes I took my grill off also. What are people doing there with a cai such as Needswings? Is that removed or squeezed in that 1"x2" opening?
Old Nov 20, 2007 | 07:32 AM
I think they remove the piece that the end of the intake tube attaches to. But I'm not real sure, just guessing.
IGot2P
Jul 26, 2025 12:40 PM
Jul 29, 2015 06:13 PM
leaddog2015
Jul 24, 2015 10:13 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
