Headlight bulb orientation
Old Dec 16, 2007 | 09:21 AM
Andy G's Avatar
Default Headlight bulb orientation
I recently changed the main-beam bulbs on my SRT 6 for 100 watt high output types. They were the H7 variety OK but the difference was minimal so I swapped back to the originals. This was after I managed to enlist the assistance of a gynaecologist with the fitting The LHF facing bulb, ahead of the water tank, is a right Bar Steward to get at! Is it easier to remove the headlamp module, I wonder?
BTW it is possible to drop an entire bulb inside the headlamp casing I managed to fish it out with a small bar magnet otherwise I would have had to remove the headlamp.
The question is : are my bulbs correctly oriented? I've put the key cut on the bulb at the 12-o'clock position but they still seem to be shinning up at an angle. I've managed to adjust the horizontal spread using the small plastic adjuster nut on the back of the headlamp. This has improved things but the main beam just seems abysmal.
The dip is good (but then I haven't touched those). Maybe the main beam projector lens types are just inherrently bad. The ones on my pevious Jag were poor on dip but much better than the SRT on main.
Any ideas of where I might have gone wrong??
Old Dec 17, 2007 | 09:13 AM
huudoo's Avatar
Default Re: Headlight bulb orientation
wow Andy .. not sure about the replacement Bulb part looks like it might be hard to get to
i had Both my headlight's replaced under warranty..
Whole Headlight Replacement
1 there are 2 bolts / screws holding them in ..
2 take out inner finder plastic covers
3 slide the headlight down , take out under the fender
my headlights have a Vertical/ up & down adjustment on the back has a white *** .
from my understanding their are no adjustments for Left to Right
smfrycruzr
Jul 17, 2023 05:33 PM
Franc Rauscher
May 9, 2016 12:04 PM
toob
Sep 26, 2015 11:44 AM
RacerXofFL
Sep 15, 2015 05:00 PM
maxcichon
Sep 4, 2015 12:50 PM
