Bypass Valve / Blow Off Valve
Old Jan 6, 2008 | 05:10 PM
bobo54545's Avatar
Default Bypass Valve / Blow Off Valve
Now let me start of by saying I'm not trying to put some huge ridiculously loud BOV on my car. This may be a dumb question, as I do not know if the SRT-6 has a bypass valve already or not. Anyways I was sitting at a drive through the other day with my window open and revved the engine up to 1000 rpm real quick because I was bored and as the rpms fell it sounded like the car wanted to pop (almost like the burnoff flames you see out of cars with huge turbos thrown on them). I did this a few more times after noticing it and it did it every single time. That being said to me it feels/sounds like the pressure from the supercharger has no where to go when the rpms start dropping and I was curious if this was the case and if a bypass valve or blow off valve might be a little healthier for the car. I know the engineers probably did or would have thrown one or the other option if they thought it was needed, but I was just curious. Thanks for any replies.
Old Jan 7, 2008 | 04:27 PM
HDDP's Avatar
Default Re: Bypass Valve / Blow Off Valve
There isn't a "blow-off" valve per se'... because there really isn't a need for one since the the SC will not build any notable back pressure with a PCM moderated electrical clutch that disengages when not under throttle conditions... Also, there are 4 vacuum lines attached that will vent any pressure...
Not sure why you would be hearing a "pop" though...
Old Jan 7, 2008 | 05:12 PM
maxxm's Avatar
Now I'm confused. I thought the SC didn't even engage until higher rpm's -- about 2,900?
Old Jan 7, 2008 | 05:39 PM
HDDP's Avatar
Actually the PCM is progammed to engage it at RPM's below 3,000 and is dependent on all the funny little sensors. TPS and MAF / MAP are the principals... But you are partially correct... Averaging would be about 2,500 rpm...
And I think that's what my original answer to the question was... It will disengage prior to building-up back pressure... Thus, no need for a blow-off valve... Get it ? Back pressure from the SC spinning and the cylinders not...
Old Jan 11, 2008 | 08:18 AM
bobo54545's Avatar
Thank you guys for the replies, clearly I am over listening to the car, although the kid inside of me kind of wanted a reason to put a BOV on the car.
syfi
Mar 28, 2026 04:14 PM
minimayhem
16
Aug 23, 2016 07:47 AM
Billy22Bob
Sep 26, 2015 10:16 PM
maxcichon
Sep 25, 2015 02:55 PM
RacerXofFL
Sep 15, 2015 05:00 PM
