Car seems slower, any ideas? Boost Gauge Question as well.
Old Jan 24, 2008 | 10:07 AM
H.K. Phooey's Avatar
Default Car seems slower, any ideas? Boost Gauge Question as well.
When I bought my SRT-6 I could here the SuperCharger often. Now it seems the car is slower and I don't notice the SC sound as much if ever. It's under warranty and bone stock. Any ideas of what I should ask the dealer when I take it in? Can I take it to a Mercedes dealer under my factory warranty?
Does anyone have an after-market boost gauge and if so, any pics of where you mounted it. What kind, size and so on.
Thanks,
HKP
Old Jan 24, 2008 | 10:13 AM
cgocifer's Avatar
Default Re: Car seems slower, any ideas? Boost Gauge Question as well.
Could be a failed SC clutch or more than likely a failed IC pump. Unfortunately the IC pump failure is very, very common on this car as well as the SLK AMG. Do a search for IC pump failure on this forum. TONS of threads about it.
Old Jan 24, 2008 | 11:30 AM
Emthusiast's Avatar
There is a long thread on "Sometimes Sluggish Acceleration". That should answer your questions.
Old Jan 24, 2008 | 11:34 AM
msheredy's Avatar
Thanks,
HKP
If your car has really slowed down, for example when on the freeway and you floor it and the car doesn't accelerate like mad, then it is the intercooler water pump. If your car acts like this then printout several threads from here and MB forums as proof of the problem.
These cars do have a dead zone in the powerband too (40-50mph). So sometimes when you punch it the acceleration is there but just not as fun. Also the ECU is an adaptive one which means if you normally putt around town it remembers that and the next time you floor it the ECU thinks, "Nah he/she doesn't want to go that fast," so it doesn't behave the way you expect it. The throttle reset will cure this problem.
Throttle reset thread
No Mercedes will not honor your warranty.
There are a few guys who have installed gauges, I have yet to install mine since I need my Dad's shop in order to do so. As for the mounting methods there aren't any besides doing something custom. Here is a link to the thread that I started.
https://www.crossfireforum.org/forum...ht=gauge+setup
Old Jan 24, 2008 | 11:40 AM
I'm going to re-set the ECU again and hope this works. If not she is going in quickly cause I feel the need to waste some fuel.
Did I mention how much I like this forum?
Old Jan 24, 2008 | 01:39 PM
NeverEnough's Avatar
I can almost promise you it's the Intercooler pump. I would bother having a dealer fix that. I would just replace it myself with the Johnson Pump. It flows more and doens' cost much. You can also go to a Ford Dealer and request a pump for a Ford Lightning. They are the same bosch pump aside from the plug, which is easy to change. They cost about $80 from Ford and about $600 from Chrysler...
Do a Search for Johnson Intercooler Pump And Ford Lightning Intercooler Pump. There are how-tos on here with part numbers and such...
Old Feb 17, 2008 | 06:20 AM
huudoo's Avatar
if you drive the car with the ic pump out,
will it damage anything.
Old Feb 17, 2008 | 08:40 AM
I bought my IC Pump from LET yesterday.
WindRestrictor
Jun 16, 2015 12:18 PM
pizzaguy
Jun 12, 2015 09:29 AM
RyanB
Jun 11, 2015 10:25 AM
WindRestrictor
Jun 1, 2015 02:31 PM
mouserider
Jul 17, 2003 02:45 AM
