lower rear...
Old Feb 3, 2008 | 12:08 PM
tttosrt6's Avatar
Default lower rear...
Is it just me or the srt-6 has a very lifted look on the rear?... we have 19" wheels on the back and the distance between the fender and the ruber is higher on top of the wheel than it is on the sides of it. is there a way to lower the rear just 1 inch without having to worry about toe, camber and new shocks? And also would it look stupid leaving the front the same?
Old Feb 3, 2008 | 02:03 PM
ws6vert's Avatar
Default Re: lower rear...
Some have cut the rear springs just a small amount, about a half a ring. I plan to soon. Easy to remove hte rear springs also.
Old Feb 3, 2008 | 02:05 PM
Maxwell's Avatar
I haven't had a chance to do the fronts, I think they are the most difficult and might require a special spring tool from MB
Old Feb 3, 2008 | 02:47 PM
BrianBrave's Avatar
<--- Huge Horsepower
I lowered my ride by trimming all 4 springs without the need of a spring compressor. Pretty easy job - search for my thread.
Old Feb 3, 2008 | 03:00 PM
No1Piranha's Avatar
If you're going to lower the height it would be worth getting a set of progressive rate springs. Cutting stock springs will work, but the ride compromise can be pretty bad. Eibach springs would give you the drop you're looking for (??? if available for the Crossfire). Not only are they progressive rate but much better made than most stock. There's a lot more meat to them. Reducing the spring height will wear the stock dampers as they'll be more compressed due to the reduced suspension travel.
55chevy
Jul 22, 2024 02:31 PM
Oct 1, 2015 01:42 AM
Power Sedan
Sep 20, 2015 09:24 PM
ayebb
Sep 18, 2015 03:35 PM
waldig
Sep 17, 2015 10:35 AM
