Gas Tank
Old Feb 12, 2008 | 04:26 AM
mousegu's Avatar
Default Gas Tank
I've read that the gas tank is inside the barrier between the seats and truck space on the crossfires, but I was wondering how much room there is to work with?
There are some mods I was thinking about doing, but I'd have to screw into that barrier. If theres a inch or so of room I'll be fine, but i obviously don't want to screw right into the tank.
Old Feb 12, 2008 | 05:19 AM
Stogey's Avatar
Default Re: Gas Tanke
Someone posted some pics of the bulkhead disassembled and the tank exposed just a couple of days ago. Don't remember who it was, but you could try a search !
Just my Dos Centavos !
Old Feb 21, 2008 | 01:18 AM
mousegu's Avatar
thanks! I found those picture youwere talking about, but it still doesnt really show where the gas tank actually is.
has anyone tried putting screws in? any problems?
Old Feb 21, 2008 | 05:21 AM
crossbowme's Avatar
If you down load the service manual, there some diagrams about that area. That document may give you the info you need.
Old Feb 21, 2008 | 05:53 AM
maxcichon's Avatar
Exclamation Re: Gas Tank
http://homepage.mac.com/gregmeach/XFire/
Andrew, can we sticky this?
Old Feb 21, 2008 | 08:28 AM
MMZ_TimeLord's Avatar
To answer your question, the fuel tank is located BEHIND the actual barrier. It is covered on the cargo side by a titanium (YES Titanium) plate. If you are going to screw into the side facing the seats, you should be okay. If you are going to screw into the cargo area side, the only steel to screw into is near the top, where it's vertical. The angled portion is the cover plate for the tank.
Hope that helps.
Old Feb 22, 2008 | 02:53 AM
mousegu's Avatar
Hope that helps.
sweet! thanks.
paine2907
Oct 2, 2015 10:01 AM
RacerXofFL
Sep 15, 2015 05:00 PM
BEATv1
Sep 10, 2015 12:58 PM
MickeyNasty
Sep 6, 2015 08:29 PM
onehundred80
Aug 12, 2015 03:08 PM
