Can spiders cause problems in the Crossfire?
Old Aug 8, 2015 | 11:57 AM
Default Can spiders cause problems in the Crossfire?
Read this and decide if we could potentially have problems. Remember the Crossfire gas tank that was crushed due to the negative pressure in it?
Old Aug 8, 2015 | 02:12 PM
maxcichon's Avatar
Default Re: Can spiders cause problems in the Crossfire?
I would LOVE to explain that claim to an adjuster.
I don't think there is anyway in the world a web could block the lines tight enough to hold that kind of pressure. I would think it would take .5 bar (1/2 atmospheric pressure/7.4 psia) to start collapsing the tank. Do you? You're an engineer. Whadda' ya' think? I just work with vacuum systems alot.
Enough of a plug to throw a code? maybe, yeah?
Old Aug 8, 2015 | 03:42 PM
True enough but suppose some other part collapses first, like a rubber hose. The physically weakest part is the first to go in scenarios like this, causing a chain reaction at times.
Can a fuel pump suck the chrome of a trailer hitch?
Old Aug 8, 2015 | 04:32 PM
maxcichon's Avatar
Well, that would depend on the fuel pump and the hitch, no?
LOL!
Aren't our gas caps vented? Or hermetically sealed? I suppose that the issue of the "loose" caps throwing the EGR code, sealed would be my guess.
Keep a can of Raid in the Bug Out Bag next to the Instant Detailer?
Old Aug 8, 2015 | 05:03 PM
LOL!
They are vented through the charcoal canister and keep a slightly lower pressure in the tank when the cap is on to prevent as much pollution escaping as possible.The gases in the tank go out through the engine. There is a valve that operates at times to release the gases. Something like that anyway, I have forgot most of what I read at one time.:
This is not your dads gas tank.
Old Aug 8, 2015 | 05:34 PM
maxcichon's Avatar
Yep. And Nope. I guess I knew how it worked-if I had the energy to think about it.
Old Aug 8, 2015 | 05:58 PM
Thinking at my age hurts so I try to avoid it as much as I can.
I think I was once smarter than I am now but maybe that's just an illusion.
Old Aug 9, 2015 | 09:29 AM
waldig's Avatar
Talking Re: Can spiders cause problems in the Crossfire?
Just my 2 cents, not a spider. A wasp with a mud plug could be a better chance at high negative pressure. Id think that 1/2 Bar negative would deform the tank but that is a bunch for a pump to do and it would require running the fuel out in a short time, not over days. Wdy
Old Aug 9, 2015 | 09:41 AM
Here is a blast from the past, a collapsed gas tank in a Crossfire, although no insects are blamed here.
Marvel at the price of a new gas tank from Chrysler, I'll take two and keep one as a spare.
No insects just leaches.
Old Aug 10, 2015 | 07:13 PM
rush549's Avatar
I knew a girl...
Old Aug 12, 2015 | 03:08 PM
Trenzman's Avatar
Can spiders cause problems..... Only if they are crawling up your leg or face while your driving
BEATv1
Jul 16, 2015 09:40 AM
wbaker1970
Jun 17, 2015 08:57 PM
BEATv1
Jun 12, 2015 05:20 PM
MJPowers
Jun 8, 2015 02:34 AM
mouserider
Jul 17, 2003 02:45 AM
