to Wrap or not to Wrap
Old May 13, 2008 | 01:15 PM
huudoo's Avatar
Default to Wrap or not to Wrap
wondering about wraping the CAI some way!
summer is comming anyone drive their last summer?
i remember the Vapor Lock years ago on older cars
will this be a problem with the CAI on the SRT-6
i think u guy's call it heat soak . thanks
Old May 13, 2008 | 01:27 PM
BlUEMDsrt6's Avatar
Default Re: to Wrap or not to Wrap
I'm thinking of wrapping my NW intake too.
Old May 13, 2008 | 01:49 PM
GatorLCA's Avatar
I too was thinking this since I'm in FL. I've noticed a slight drop in power with the added heat and dense humid air here in FL. Not sure how much the wrapped CAI will help but at least I know I'm doing everything I can to keep it cooler
Old May 13, 2008 | 01:54 PM
Chi-Town SRT/6's Avatar
save the wrap for you jimmy...and i'm not talking about the GMC type...
Old May 13, 2008 | 05:16 PM
RMADERMAN's Avatar
Mike, ask John, the Toy. His is dual, but is wrapped.
Old May 13, 2008 | 10:10 PM
NeedsWings's Avatar
we can get you the wrap if you have your mind set on it but i wouldnt bother
Old May 13, 2008 | 10:17 PM
NeverEnough's Avatar
I wouldn't bother either. The biggest influence on your Intake Air Temps will be the effiecency of your Intercooler Setup. These intakes work as well as they do from the increase in air flow, not air temperature. Your Intercooler does that. I'm not saying the wrap won't help, it may. I just serioulsy doubt you would notice the difference. I wouldn't waste the time, $$$, or effort.
Old May 14, 2008 | 07:17 AM
tom2112's Avatar
She can ride with me ;)
Pardon the "for dummies" question, but isn't wrap usually used on the exhaust to reduce engine compartment temps?
Old May 14, 2008 | 07:25 AM
Opticon's Avatar
You're thinking "header wrap". A tight fitting, flame retardant, heat absorbing woven fabric that can actually destory heated exhaust tubing due to a lack of expansion.
I think this thread is in reference to a loose "insulated pipe wrap". The intent being to stock engine temps from heating up the CAI pipes and ambient intake air.
Old May 15, 2008 | 01:14 PM
huudoo's Avatar
ok something like this, but i talked to Rob today @ NW and he don't think it is needed.... thanks for the input
Old May 15, 2008 | 02:14 PM
bobo54545's Avatar
Well incase you still want to see what it looks like heres a picture of my Needswings intake that I wrapped. Its just some high temp reflective wrap from autozone. Before I wrapped it I used an IR thermometer to see the temp of the intake and it was usually 120 F. So although some people think it won't matter, it doesn't seem like feeding cold air through a hot pipe will keep the air as cold as possible.
Old May 15, 2008 | 03:00 PM
huudoo's Avatar
so did the temp drop any ...?????????
not to pretty but not bad if results are good. thanks
Old May 15, 2008 | 03:48 PM
MD SRT6's Avatar
I think once the air enters the filter it is consumed in the engine before any heat soak from the hot intake tube can influence it. I think it draws 600 or so cubic feet per minute, (just guessing) but the air is only in the tube under acceleration for miliseconds. I think the temp of tube is irrelevant. I think the temp of the air ie. outside vs inside the engine compartment is the real difference.
Old May 16, 2008 | 11:02 PM
bobo54545's Avatar
Well the intake dissapates the heat a lot quicker with this wrap on, in other words if I park it it cools down in a matter of minutes where as without the wrap it would stay warm for a good while. As for actual intake temps, I have no sort of sensor or monitoring equipment set up so I can't tell you what effect it had on it if any.
I spose the only thing I could say to the fact that it may help is that throughout my whole night of dragracing tonight the times did not seem to drop off despite the engine being super hot for my first run and not any cooler for my second run and then for my third run I actually just circled around and got staged right away again.
https://www.crossfireforum.org/forum...121#post239121
theres a link to my thread with my times.
I don't know that it actually does anything and I am not going to argue with anyone that it does, but I figure it can't hurt. I would assume there is a possible effect, only because they do sell those C02 bulbs you can put in the middle of your intake to cool your intake temps, and air to air intercoolers have air passing through them just as fast but they seem to have some sort of effect. I'm no physicist nor do I play one on tv, but I just started a job as a maintenance mechanic, and am learning a lot about heat exchange in very different applications so I tried to apply that here and see what happens. Anyways good luck with whatever option you choose ( I think you already chose not to).
Old May 18, 2008 | 04:29 PM
huudoo's Avatar
in works.........................
Old May 18, 2008 | 04:50 PM
bobo54545's Avatar
Does that mean you plan on running your headers straight up and out the hood? I'm confused.
Old May 18, 2008 | 06:26 PM
huudoo's Avatar
nope ! just thought it would add to the thread as a funny
after driving for a while i opened the hood
and the CAI was cool to the touch ... No Wrap for me Thanks though
Old May 18, 2008 | 08:31 PM
RIOT's Avatar
Wrap looks like **** to me....it belongs on a John Deere or a baseball bat or my snow blower.
Old May 18, 2008 | 08:36 PM
SRTpowa's Avatar
x2
Not worth it IMO
Old Aug 22, 2008 | 01:58 PM
huudoo's Avatar
remember this
