Rolling radius?
Old May 16, 2008 | 03:37 PM
GIdriver's Avatar
Default Rolling radius?
Does anyone know the rolling radius of the rears? I'm trying to crunch some numbers, and cant find it. Either my info or math is bad. If anyone knows or could measure it would be greatly appreciated.
thanks
Old May 16, 2008 | 03:48 PM
robby363's Avatar
Default Re: Rolling radius?
thanks
I think it's 26" and about 800 revolutions a mile.
Old May 16, 2008 | 04:04 PM
GIdriver's Avatar
Ok, im running the math on the SRT 6.
So far....
Drive wheel torque = 2908.187,
Wheel thrust = 2692.737 ?
I need an accurate rolling radius measurement for accurate #s, And all other equations rely on these base numbers.
I tend to do insane research, and I am trying to plan a build from iraq, (royal pain)
any help here would be great.
GIdriver's Avatar
Deleted, NIPR flashed.
Old May 16, 2008 | 04:13 PM
robby363's Avatar
What do mean by the rolling radius? how many revolutions per mile?
Old May 16, 2008 | 04:24 PM
MD SRT6's Avatar
Looking at your calculations, I think maybe you mean gear ratio, I believe it is 3:07-1 on the srt6. Hope that helps and be safe over there and thanks for serving
GIdriver's Avatar
The rolling radius is the vertical measurement from the center of the wheel to the tire's point of contact on the ground. I have to equate for the weight of the vehicle as it slightly compresses and flattens the tire on the contact patch. Its a minimal value, but its pertanent in the equations.
Old May 16, 2008 | 04:28 PM
MD SRT6's Avatar
You lost me! Have fun.
robby363's Avatar
Wouldn't it be dfferent depending on the tire.
Old May 16, 2008 | 04:30 PM
GIdriver's Avatar
I have the ratios, I just need to confirm my numbers on the wheel thrust. Do the numbers look accurate to you? Been working 18 hours and my minds not as sharp as it should be. Right now coffee equals conciousness.
Old May 16, 2008 | 04:38 PM
GIdriver's Avatar
I'm basing all equations on factory specs.
Old May 16, 2008 | 04:57 PM
25" top to bottom, so 12.5" is what you are looking at roughly, thanks for your service...by the way, Doc
Old May 16, 2008 | 05:00 PM
GIdriver's Avatar
Thank you Doc, an I'm proud to serve. i will post all my numbers once ive finished.
velociabstract
28
Oct 28, 2015 12:46 PM
cjw
Oct 26, 2015 10:26 PM
cjw
Sep 27, 2015 10:22 AM
blackpepper
Racing
16
Sep 27, 2015 01:38 AM
x1xsinisterx1x
Aug 24, 2015 07:31 PM
