Price of Gas
Just a litle oil educion... In the heirarchy of oil refinement you have basic categories of refinement and production...they are as follows:
(most refined to least refined)
Jet Fuel/Kerosene
Premium Gas
Mid-Grade Gas
Regular Gas
Diesel
Heating Oil
Asphaltine (Use to make asphalt)
you can get each one of these products out of a single barrel of crude, however the amount are not going to be equally distributed across all categories...
just my educated $.02
Jet Fuel/Kerosene
Premium Gas
Mid-Grade Gas
Regular Gas
Diesel
Heating Oil
I will definitely continue driving my SRT, but I might start looking more seriously into a daily driver now. I wonder if my job would mind me tying my horse up in the parking lot??? I heard in the Middle East, Saudi Arabia to be exact, that gas was still around $1.00 per gallon. Boy would that be nice. Maybe I will move there and drive a cab or something.
Jet Fuel/Kerosene
Premium Gas
Mid-Grade Gas
Regular Gas
Diesel
Heating Oil
Jet Fuel/Kerosene
Premium Gas
Mid-Grade Gas
Regular Gas
Diesel
Heating Oil
Kerosene is more highly refined? You wouldn't think so considering how much smoke it produces.
Originally Posted by NeverEnough
http://www.cnn.com/video/#/video/tec...ypermiling.cnn
don't be this guy! What a retarded zealot. I'd seriously pay the extra $50 a month in payment and just get a hybrid...
I'm currently averaging over 22 MPG in my SRT and that's ony about 50% highway, so you can tell I'm watching every drop...
I'm not doing much recreational driving anymore. No more "taking the long way home".
Edit: After reading/thinking about this some more, I think this is a really, really bad idea. I'm just going to start driving the speed limit.
Originally Posted by Kurts
Thanks, Matt! Suspicions confirmed. So, if diesel is less expensive to refine & it has to be used less than gasoline just why is it priced so outrageously? Supply & demand don't seem to apply here.....wait, I think I see.....less diesel is being produced in order to produce more gasoline. A "limited" amount of oil so more of the barrel is being carved-up for gas.
I'm thinking that the more it's refined the more energy you could get out of a gallon hence why it's used as jet fuel. It's just confusing because I always thought (from who knows where!) that kerosene was a low energy fuel simply because it always appeared to be smoky.
Another mystery......
When did kerosene start smoking? Thats what they use around here to heat homes and garages "inside with no vent at all". Kerosene burns extremly clean and has no smoke at all that I've ever seen! Plus its basically jet fuel and I never seen a jet smoking either?
Jet engines supply plenty of air to the combustion chamber. Old ones smoked, not from the fuel, but from the lubricating oil pumped to the inner bearings to keep them cool. Newer, high bypass engines have overcome this problem and do not dump the oil into the combustion stream.
Kerosene is extremely clean burning. We used to put it thru our engines to burn off carbon deposits. But that was back in the old,old, really old days.
Wouldn't even think of doing it now.
roadster with a stick
Originally Posted by rock
I actually watched a segment on CNN yesterday about that guy. Is it harmful to your vehicle to cut your engine while in drive (autostick) and coming to a stop, and do you guys think the savings would be significant (if you're at the light longer than 10 seconds or so)?
If the guy was a true zealot he would have had a Honda with a manual tranny. Coasting is a great way to save on fuel usage, and staying off the brake is too. Sitting at long traffic lights with the motor running wastes gas also.
I drive for a living. I use a Honda Civic, and a 1 ton Chevy extended window van. On the highway at 70 mph I get around 38 mpg, but if I slow down to around 60 mph I can usually pull over 40 mpg. with my Civic.
Around town it's so easy to shut off the motor and coast, (sometimes for as long as a mile at a time) before popping the clutch to start the motor again. I know the skeptics say it's not worth the extra effort, but believe me it does add up.
On a recent 400 mile round trip that I make on a regular basis, I drove normally and averaged 38 mpg, but the next time I made the very same trip and raised my average to a little over 40 mpg using some of the techniques shown in that video. Figuring $4.00 per gallon, I saved over $20.00, enough for a cheap steak dinner for two at our local Texas Steak House.
Albeit, if you live where the roads are really flat, coasting isn't much of an option, but here in N.E. Ohio there are lots of hills. I live on the outskirts of Akron Ohio, most all my trips start with me driving West for about 7 miles, to a location where I purchase most of my groceries and gas up the car.
I discover that just by paying a little more attention to the lay of the land, and traffic, I can coast 4 of those 7 miles going west, and over 3 going east. In other words, cutting my fuel usage in half.
Like I said, it all adds up, but you need a manual tranny to really reap the benifits.
There is a similar procees to corn ethanol using sea weed and algae. Things we dont eat would be a better fuel source, but seaweed doesnt vote or make political contributions so it will never happen.
Whales and Dolphins don't vote but they carry a lot of clout in DC.
Seaweed grows off the costs of California all the way up to Washington. Can't touch that "pristine" evironment off the coasts of Blue states.
Wouldn't want to mess up Barbara Striesand's view.
Or put windmills off the coast of Massachusetts and spoil Ted Kennedy's sailing.
As of this evening: full serve avgas if over 50 gallons purchased - $5.86, under 50 gallons - $5.99. Jet fuel - $5.99.
Does anyone know if diesel is higher because of storage and distribution costs?
I talked to my son in law about wind generation, he is a lineman in Montana. His comment was, the idea of wind generation is a great idea only once they built some of the facilities they forgot to ask the tree huggers if they could build power lines from the plants. I guess that was not in the orginal legislation and so guess who won.
We have many of the turbines popping up around the home state here. It makes sense, fairly cheap & everytime I see one it makes me think "well, there's less barrels or a few less cubic yards of natural gas used".
Just a thought - couldn't they bury the lines ( I know this would a heck of lot more expensive) & make everyone happy?
Figures.....
LOL!!
Earthworms, how could I be so foolish as to forget the Earthworms!
I see a "Save The Earthworms" movement starting as we type!
