Code3 Supercharger Pulley question
Old Jun 18, 2008 | 01:19 PM
Bubba89's Avatar
Default Code3 Supercharger Pulley question
I just recieved my Code3 Supercharger Pulley a few days ago and I checked the box and there was only 1 spacer included. It was taped to some rubber piece. If I'm not mistaken I remember reading that the pulley is supposed to come with 3 spacers to allow for proper fittament. I tried contacting Code3 Performance many times by phone and email and I still have not recieved a call or an email back, so I was wondering if any of you guys could help me clear this up. Did anyone else's pulley only come with 1 spacer?? Any help would be appreciated.
Old Jun 18, 2008 | 01:33 PM
Bubba89's Avatar
Default Re: Code3 Supercharger Pulley question
Here are some pics.
Old Jun 18, 2008 | 01:52 PM
BLKFIN's Avatar
ADDICTED TO BOOST
My pulley had 3 spacers. They may have fallen out in transport or the new version (yours) may be built to closer specs and not need but one. I know Brandon (Code 3 ) travels quite a bit, but I am sure he will get back with you soon.
Old Jun 19, 2008 | 04:36 AM
bikecop's Avatar
I agree with Blkfin, you have the newer version and may only need one.
Old Jun 19, 2008 | 02:14 PM
svo's Avatar
svo
What was the difference with the newer version?
Old Jun 19, 2008 | 04:05 PM
Coyote's Avatar
Are you sure that they are not just stuck together by a light coating of
oil? When I got mine, the spacers appeared as one, and I found myself
looking in the box for the others. Not finding any, I tried to see if they
were just stuck together and was able to slide them apart with a little
pressure. Or, maybe it is the new design.
Good Luck
Coyote
Old Jun 19, 2008 | 08:58 PM
PA/XFIRE's Avatar
I got 3 with mine,i didn't know they had a new version. ILLCYA
Old Jun 20, 2008 | 09:24 PM
Bubba89's Avatar
Good Luck
Coyote
I just checked again to make sure, there is definitly only one there. As for it being a newer version I'm hoping you guys are right and its a newer version because I still have not heard back from Code3. I have not installed the pulley yet that should happen tommorrow, but I'm hoping all goes smoothly or I'm gonna be one unhappy customer .
Old Jun 22, 2008 | 10:06 AM
Eleventeen's Avatar
Yours has to be the new one. I have the original and it has anti-slip grooves cut perpendicular to the belt grooves. I think Brandon removed them because people were concerned about premature belt wear (although the Cobra guys regularly use this type of grooved pulley).
Old Jun 22, 2008 | 10:30 AM
mrphotoman's Avatar
it is a super simple install, just try it and measure the gap. if it is within the correct tolerances then you are good to go. i would get a strap wrench, it makes it even easier to install!
Old Jun 23, 2008 | 03:43 AM
Bubba89's Avatar
I actually just installed it two days ago. The install went pretty easily and I actually didnt end up using the 1 spacer that was provided to me. I checked the tolerances with the stock spacer on there and it seemed to be .32mm which is a little above but close enough to the tolerances Cod3 suggested. I'm not too car savy or tool savy ha so I want to make sure that I'm correct on this one, how would i know if I actually needed that spacer. I thought i measured the tolerances correctly but there was some confusion during that process, i'll choose not to explain hah, and also the Code3 pulley seemed to be crafted a little uneven, as when i hand turned the pulley I could see that the tolerances, at least the tolerances on the edge of the pulley, change. It just concerns me that your guys pulley came with 3 spacers and most of you used them all and mine came with 1 spacer and I didnt even use it. What are the tell tale signs that my tolerances are too low? Anything I should watch out for? Oh and the first ride my belt slipped twice but after that the tensioner must have adjusted becasue I havent had a problem yet that I can see.
Jonacross
20
Jul 17, 2017 11:19 PM
zackman62
Nov 6, 2015 12:37 PM
Mackel
Oct 16, 2015 09:03 AM
BEATv1
Sep 10, 2015 12:58 PM
davidc90
Sep 6, 2015 10:37 PM
