Failed 3-way Cat
Old Jul 22, 2008 | 02:22 AM
bamp's Avatar
Default Re: Failed 3-way Cat
I have the same problem on my XF, its down at the local dealer getting a new 3-way cat fitted under warranty. Cost is @ £800 (@$1600)
Old Jul 22, 2008 | 01:37 PM
huudoo's Avatar
Converters do not go bad NO MOVING PARTS
something causes them to have failure .
antifreeze - raw fuel lite off in the Converter - Damage
you need to find out what caused the failure
Old Jul 22, 2008 | 01:43 PM
bamp's Avatar
dealer said it was bust - it rattled every time i set off at low revs - all fixed and no more rattles
Old Jul 22, 2008 | 04:47 PM
kapium's Avatar
I'm going to make them give me the original converter to inspect. This car sat on the east cost for a long time, then on the Dealership in Texas for almost a year. Likely it was cold-started and run a few times. Raw fuel in the converter can rot it out, that is likely the cause.
Old Jul 22, 2008 | 04:52 PM
radmanly's Avatar
Did anyone ever come up with the part # for this piece?
Old Jul 22, 2008 | 06:12 PM
Stogey's Avatar
Is this type of set up something specfic to European Crossfires ?
Old Jul 23, 2008 | 10:03 AM
srtdrew's Avatar
Since no one seems to be able to follow links on this forum...
Taken from here:
Originally Posted by srtdrew
Sounds like someone at the dealer is confused and/or doesn't know what they're talking about. I had BOTH banks, 4 cats total as front and rear cats are on one section of pipe, replaced on my SRT just over a month ago and the dealer had no issues getting them or installing them. They even told me at the time that they were in-stock in their warehouse.
The part numbers off of my invoice from the warranty replacement from the dealer are:
5135432-AA Converter 14070004
5135433-AA Converter 14070004
Hopefully you're getting them replaced under warranty as I was told the price was $2,250.00 each!
Not sure if I helped at all as it looks like you already had the part number correct, but hopefully you can work it out. Guess you can always try another dealer.
Old Jul 23, 2008 | 07:36 PM
kapium's Avatar
Taken from here:
Thanks, I actually figured it out today with the help of Mercedes. Apparently my dealer did not have a parts breakout showing the SRT-6 specific parts, so they had the right part all along but thought it was wrong because they had never worked in an SRT-6 exhaust before, and the illustration showed the setup for the standard model, which is very different. To make matters worse, they don't have my car so they couldn't just look and see.
At any rate I'm all set now. Also, the parts match the Mercedes SLK32 parts, as expected and I now have the Mercedes cross-reference for these. I'll post them here tomorrow after I get them off my desk at work so if anyone needs to replace them out of warranty they can just order the parts from Mercedes. They are $1,450 per side from mercedes, but $2,300 from Chrysler. The dealer did verify the matching Mercedes part numbers stamped in the side.
Idrenak
Sep 19, 2015 08:17 PM
Valk
Sep 17, 2015 11:43 AM
RacerXofFL
Sep 15, 2015 05:00 PM
smokey847
Sep 15, 2015 10:47 AM
Sep 13, 2015 02:12 AM
