Fan Kicking In?
Old Sep 16, 2008 | 08:38 AM
smokey847's Avatar
Default Fan Kicking In?
On my way to school this morning, the temperature was 66 degrees. First of all, yesterday when I was driving the same route, I noticed that my low tire pressure monitor was on. When I got home, I checked each tire and all of them were in the 30-32 lbs. range.
So now, this morning, I was sitting at a red light and I heard what sounded like a fan or something kicking in. It stayed on for maybe 4 seconds and then went off. I usually have the radio on, but I don't think that I've heard this before. Can anyone fill me in?
Old Sep 16, 2008 | 09:14 AM
reality's Avatar
Default Re: Fan Kicking In?
My low tire pressure light came on a week or so ago (its getting a little cooler in the mornings around here). I checked all the tires, fronts were around 34-35, rears were 31-32 so I put another couple of pounds in them. Restarted the car and haven't had the light turn on since. I haven't pulled out the owners manual, but I'm guessing they have to be over 32.
My car make the same sound for a few seconds then shuts off like yours. Usually right after I get off the highway. I'm sure its just a fan or something, its normal... no worries.
Old Sep 16, 2008 | 09:21 AM
cruzinquick's Avatar
There is a fan TSB out there. On the tires, I get the light in the winter as well. I've had to put my tires at 36psl in the winter. Summer can be as low as 32 and won't get a light.
Old Sep 16, 2008 | 11:41 AM
waldig's Avatar
Talking Re: Fan Kicking In?
66 degrees, did you have the defrost on/
Was the heat on as there a second I/C 'LIKE' pump to feed hot water to the cabin heat exchanger, located below the passenger headlight.
Enjoying, Woody
Old Sep 16, 2008 | 12:03 PM
distantpulse's Avatar
Mine does this all the time. It will kick in for 10 seconds or so and go off regardless of how hot or cold it is. I think its normal?
Old Sep 16, 2008 | 02:41 PM
smokey847's Avatar
Nope. I had no defrost, AC or heat on. But, since it's (hopefully) normal, i'm not worried about it. Just worried me. Thanks for the responses!
Valk
Jul 12, 2021 09:49 PM
johnnycross413
Mar 4, 2016 04:49 AM
Oct 1, 2015 01:42 AM
RiderJC
Sep 7, 2015 11:19 PM
williammt
Sep 6, 2015 11:23 AM
