Thinkin' about picking up a SRT-6...
Old Sep 27, 2008 | 09:11 AM
Wulf's Avatar
Default Thinkin' about picking up a SRT-6...
Hey all,
Haven't posted in a while but I have been lurking around the board reading everything I can. In a few months I am aiming to buy an SRT-6. I will be more than happy with stock performance and would really like to focus on making sure everything is in proper working order before I bite into the mods. I would like to know what I can expect to go wrong besides the IC pump, and this transmission leak I hear the SRT-6's have, whats the deal with that? I also know about the headlight hazing, rattly door latch, underdoor rust. Is this car prone to sensor failure? How much do sensors usually run for? I notice a few members have had trouble with rough running/idling, and hard starting and that scares me is that a common occurance or is it a hit or miss kinda thing? I don't plan on beating on this thing, very much, and I already have an extensive knowledge of automotives and my dad knows a lot about mercedes systems (S600). Consumer Report and Edmunds.com have said this is an "at or above average car" and I wouldn't know why they would lie about that, but you never know. Well, let me hear your opinions and thanks!
Zach aka Wulf
Old Sep 27, 2008 | 09:25 AM
Coyote's Avatar
Default Re: Thinkin' about picking up a SRT-6...
Hiya Wulf,
There have been several issues noted with the SRT-6 on this forum over the years,
but none have been overly serious or hard to fix (once the techs know what the problem
is). I've been driving my SRT-6 for just at 4 years now, and have had very limited
problems. I had the tranny leak, and I had the IC pump go out. Other than that, I've
had nothing serious. I have read of at least one Supercharger problem, but would
consider that a rare occurrence. These are really great cars.
Good luck on your future purchase plans.
Coyote
Old Sep 27, 2008 | 12:22 PM
svo's Avatar
svo
ditto on that... The transmission leak- if you did have to fix yourself would be like a $10 dollar fix, it's just an O-ring seal.
Old Sep 27, 2008 | 05:15 PM
Goldwing's Avatar
I have 30k miles on my roadster over 4 summers and no problems. It's been very reliable. I put about 5k on my SRT6 this summer and ran into the dreaded intercooler problem -- it's currently at the dealer for warranty repair. Otherwise it's been fine. If I had any doubts about their reliability, would I have bought a third one?
Old Sep 27, 2008 | 07:58 PM
Kurts's Avatar
Evening, Zach,
Don't wait, don't hesistate: buy one.
Remember, this is a Mercedes engine, hand built - one tech., one engine - and will probably last as long as you want it to. The Crossfire, Coupe or SRT, still ranks as one of the best, most exciting cars I've ever driven (so far!).
Speaking from personal experience only: I've had no serious issues with either car. I've had the CD head replaced twice & the passenger speaker replaced, both under warranty. Beyond tires (which are expensive) & oil changes (which can be expensive) nothing else has gone wrong.
Good luck!
Old Sep 27, 2008 | 09:49 PM
NeverEnough's Avatar
The only problems I've had are the Seat Heaters, Outside Temp Sensor, For Light reflectors, Cracked Brake Rotors, and Cup Holder. Nothing Mechanical. None of these I would consider serious. I still have the original IC Pump at 32,000 miles, so I suspect that will go any day now.
Old Sep 27, 2008 | 09:51 PM
kldiet's Avatar
I guess I'm the lucky one with the SC problem. That said, I still love this car. After taking the car to both the Chrysler and Benz dealers and both saying that I needed a new SC, I got a used one that had 18K miles on it and did the install myself. Sad to report that car makes the same top side grinding noise as with the original SC. In my opinion there is A) nothing wrong with either, B) same thing wrong with both or c) something else causing the noise. I have another thread on this problem and will be posting complete details on how to chageout the SC in a future post and on YouTube. http://www.youtube.com/watch?v=ehxL0JaYM9A . New SC with new Code-3 bearing (same as what I had done previously to my SC) sounds identical to the video. Bummer..... no real bummer. At least I didn't spend the $6000 that the Chrysler dealer wanted or the $3700 the MB dealer wanted.
Even with the SC noise, this car still runs really fast, a bit bumpy on secondary roads. In the 1 year I have had my car, only one tire air pressure sensor needed to be replaced (warranty) and the transmission leak o-ring seal.
Old Sep 28, 2008 | 01:07 AM
Wulf's Avatar
Thanks for all the replies! These sure sound like great cars and I look forward to buying one in the upcoming months. If I have anymore questions you all will be the first to hear them! Thanks.
Zach
Old Sep 28, 2008 | 08:53 PM
Brent's Avatar
I had a supercharger problem. It was actually my clutch that failed. My dealer replaced the whole supercharger assy and now all is well. Supercharger failures happen but they are far rarer than IC pump failures.
Old Oct 7, 2008 | 10:04 AM
huudoo's Avatar
99000 TIRES:PRESSURE MONITORING AND REGULATING SYSTEMSBulletin No:2200406Date of Bulletin:03/26/2007Summary Description:
TIRE PRESSURE MONITOR SYSTEM INFORMATION. *KB
03000 POWER TRAIN:AUTOMATIC TRANSMISSIONBulletin No:0803006Date of Bulletin:03/23/2007Summary Description:
POWERTRAIN CONTROL MODULE INITIALIZATION. *KB
10000 ELECTRICAL SYSTEMBulletin No:0800306Date of Bulletin:02/22/2006Summary Description:
INSTRUMENT CLUSTER INITIALIZATION. *TT
62200 ENGINE AND ENGINE COOLING:COOLING SYSTEM:FANBulletin No:19Date of Bulletin:02/22/2006Summary Description:
THE RADIATOR COOLING FAN MOTOR MAY HAVE BEEN IMPROPERLY ASSEMBLED. CUSTOMER SATISFACTION NOTIFICATION E19 RADIATOR COOLING FAN MODULE. *TT
10000 ELECTRICAL SYSTEMBulletin No:0800905Date of Bulletin:03/30/2005Summary Description:
PNEUMATIC LOCK HOSE REPAIR KIT AVAILABLE. *TT
03000 POWER TRAIN:AUTOMATIC TRANSMISSIONBulletin No:2100205Date of Bulletin:02/25/2005Summary Description:
TRANSMISSION FLUID MAY BE WICKING IN THE RIGHT FRONT CORNER OF THE TRANSMISSION OIL PAN AREA. *EH
03000 POWER TRAIN:AUTOMATIC TRANSMISSIONBulletin No:2100105Date of Bulletin:02/24/2005Summary Description:
GEAR GRIND LIKE SOUND WHILE SHIFTING. *EH
10000 ELECTRICAL SYSTEMBulletin No:0800205Date of Bulletin:02/24/2005Summary Description:
HEADLAMP CONDENSATION. *EH
62000 STRUCTURE:BODYBulletin No:2300405Date of Bulletin:02/23/2005Summary Description:
DOOR GLASS MISALIGNMENT OR CONTACTS THE ROOF. *TT
62000 STRUCTURE:BODYBulletin No:2305104Date of Bulletin:02/07/2005Summary Description:
LIFTGATE BUMPER FASTENER WILL NOT TIGHTEN. *TT
20000 SUSPENSIONBulletin No:0200904Date of Bulletin:02/07/2005Summary Description:
SQUEAKING SOUND FROM FRONT SUSPENSION. *TT
21000 EXTERIOR LIGHTING:HEADLIGHTSBulletin No:0804304Date of Bulletin:02/07/2005Summary Description:
HEADLAMP CONDENSATION. *TT
20000 SUSPENSIONBulletin No:0200804Date of Bulletin:01/26/2005Summary Description:
RATTLE SOUND FROM REAR. *TT
62000 STRUCTURE:BODYBulletin No:2304203Date of Bulletin:11/30/2004Summary Description:
DECKLID WILL NOT OPEN. *EH
10000 ELECTRICAL SYSTEMBulletin No:0803004Date of Bulletin:11/29/2004Summary Description:
ONE OR BOTH KEYLESS ENTRY TRANSMITTER DO NOT WORK. *TT
62000 STRUCTURE:BODYBulletin No:2302504Date of Bulletin:08/19/2004Summary Description:
SQUEAK/CREAK SOUND FROM REAR SPOILER. *MJ
51200 SEAT BELTS:FRONT:WEBBINGBulletin No:01012004Date of Bulletin:07/21/2004Summary Description:
THE SEAT BELT WEB STOP BUTTON HAS BEEN MADE AVAILABLE. 2005 CROSSFIRE ALSO INCLUDED. GPOP - ISSUE REVIEW SYSTEM. *TT
02000 POWER TRAIN:MANUAL TRANSMISSIONBulletin No:2100204Date of Bulletin:05/03/2004Summary Description:
FIRST GEAR SYNCHRONIZER ENHANCEMENTS. *TT
NOTE: The source of this TSB information is the National Highway Traffic Safety Administration, which maintains TSB information for vehicles sold in the United States. If we did not find any TSB's for your vehicle, that does not necessarily mean there are none. Ownersite.com advises that you contact your local dealership or visit the NHTSA website at http://www.nhtsa.dot.gov to perform another search or to get more detailed information on specific TSB's. At times, our list of vehicles (or the vehicles that you explicitly add to your Ownersite account) may not match exactly the model names maintained in the NHTSA database. For more detailed tsb information, including full-text versions, we recommend checking out eAutoRepair.net.
Old Oct 7, 2008 | 12:07 PM
Wulf's Avatar
Cool, thanks again. Keep the info rolling because..."The more you know...'", well I forgot how the rest of it oges but you know what I mean, lol.
Zach
Old Oct 7, 2008 | 06:15 PM
Voyager's Avatar
did anybody else think it was funny that a Wulf and a coyote were talking at the beginning of the thread
Old Oct 7, 2008 | 07:18 PM
Wulf's Avatar
Never realized that, that is funny!
Wulf
Old Oct 8, 2008 | 01:35 PM
ws6vert's Avatar
No problem mechanically with mine. Only heated seat failure. Owned for almost 3 years. Only 9850 miles on it. Bought it with 275 miles. Great car!!!!!!
Valk
Jul 12, 2021 09:49 PM
TOPLESS
Jan 15, 2016 12:39 PM
Canyonero
Oct 6, 2015 09:23 PM
eatmycrackers
Sep 23, 2015 09:08 AM
Bob4kacz
Sep 16, 2015 11:20 AM
