Hey LET Now What?
Old Oct 25, 2008 | 09:50 AM
H.K. Phooey's Avatar
Default Hey LET Now What?
LET, I am at the Texas Mile now. At 3/4 mark 155mph, car falls off again for about 2 seconds. It just kind of shuts off like it is out of fuel. Then it kicks back in and I am running through the mile at 152 exactly like I was running back in March. Call me 832-724-4689 or post up and I will check it. I really need you guys help. I spent a lot of money for the same results and I don't understand what is happening.
Old Oct 25, 2008 | 10:20 AM
waldig's Avatar
Default Re: Hey LET Now What?
Do you know what the IAT is getting up to, that is a long time to run at WOT. Woody
Old Oct 25, 2008 | 10:34 AM
SRT-6 Steve's Avatar
HK, call Jerry
Jerry Thornton
Phone: (312)446-6326
Email: sales@lettuning.com
Hours of Operation: Monday - Saturday 9:00AM - 5:00PM CST
Old Oct 25, 2008 | 10:50 AM
sonoronos's Avatar
Ouch...got to wonder about people who claim mods to remove the 155mph speed limiter, especially when there's only a few places one can test their claims...
Old Oct 25, 2008 | 01:41 PM
SRT6-Man's Avatar
Sounds like that limiter is not disabled.
Old Oct 26, 2008 | 01:33 PM
Well I just got home and I can't begin to tell you how bothered I am right now.
Oil change $118
New Tires $778
Hotel $278
Gas $84
Food for 3 days $100
Race Registration $195
155#'s for my car $50
Running the exact same speed as I did in March and getting beat by a SRT-4
PRICELESS
Old Oct 26, 2008 | 01:38 PM
BLKFIN's Avatar
ADDICTED TO BOOST
Sorry to hear this Phooey, we all were looking forward to hear how you did. I have a feeling that the LET tune does not remove the speed limiter. I hit 150 + on the dyno one time and the ECU made it cut out right at 155. I have the latest tune now, but have not pushed it on the dyno to see what happens at 155.
Old Oct 26, 2008 | 02:02 PM
I had started another thread, spoke with Jerry and Wayne to make sure the speed limited was set to 210mph, both really nice guys but...the car shut down/pulled timing at the 3/4 mile mark right at 155mph. I'm frustrated to get out there to run with the big dogs and end up limping back to the pits with my tail tucked between my legs.
I'm honestly crushed and my spirit is broken.
Old Oct 26, 2008 | 02:05 PM
I don't understand it either. There are guys on here with the same tune that are hitting 170 - 180mph.
Steve
Old Oct 26, 2008 | 02:08 PM
SRT6-Man's Avatar
Oil change $118
New Tires $778
Hotel $278
Gas $84
PRICELESS
I had powerchip-group remove my limiter, but have no idea, since the fastest I've gone is 135. I heard that it was hard to remove the limiter on our ECU. This car is capable of 180 I'm sure of that. Let I us know what you find out.
Old Oct 26, 2008 | 03:30 PM
I don't think this will apply but I had the LET tune...was hot ******* w/ a friend on an old abandoned road I like to play on, took a hard hair pin turn, done this several times in the past, when boom, with the traction control off, like always, it over rides and comes on, and I have no choice but go with it into a 360, saving the car. I always power thru that turn...contacted Wayne, who informed me the car still has a memory. That I would need to re-set the memory, meaning undo the negative cable for a short time to blank the memory and car should return to the original tune...I did this and sure enough the car runs better...but I didn't get a chance to confirm this not making the test and tune a few weeks ago...I certainly would look into it, my tune is supposed set to 190 mph...but can't confirm that either rt now...
Old Oct 26, 2008 | 04:13 PM
Old Oct 26, 2008 | 04:30 PM
CIMG2872.jpg?t=1225036314
Old Oct 26, 2008 | 04:37 PM
that tire going boom had to hurt...looks like he held it though...mine before tune cut out a 158, of course, @ that speed, it could have been 155...I was busy looking up more than down....but got there in 9/10ths of a mile from a standing start...sry to here about the tune problems...I am still wondering about mine...
Old Oct 27, 2008 | 03:14 AM
SLK32Germany's Avatar
Hi, from what you say, I don't think its the speed limiter, because the speed limiter normally takes back the power very SOFTLY, no jerks or fall offs for 2 Seconds...I think your IATs rised over 200 Degrees F, which results in a Supercharger-Shutdown. After cooling down to 155 Degrees F the Supercharger normally kicks back in. This is to protect your Engine! I recommend to datalog your IATs with a OBD2-Tool...
Regards
Old Oct 27, 2008 | 04:07 AM
Montana Crossfire's Avatar
I have to agree with SLK32 I have been visited by the dreaded speed limiter and it just feels like, there is no more. Gracfully stops your exceleration but never feels as though it is cutting out or anything which gives that sensation.
Plus, I have one of Jerry's latest tunes and mine does way better in a mile than 155!
Are you a "Quarter Mile Freak"? Because if you are you may not do better than that. Let me explain. When I got my tune (I drive Road Courses) Jerry asked if I would need my car to sustain speeds of 160mph through corners. This is when you put the most demand on the engines need for fuel and torque. If you are lean enough for the strip you probably are not rich enough for the extended pull of the "mile". My thought "you can't have it all".
Mine's done 175 and there was more under the hood than there was asphalt!
Mike
Old Oct 27, 2008 | 06:09 AM
waldig's Avatar
WHen I autocrossed for a minute at full power in 1 and some 2nd gear I got heat shut down so bad that it threw codes of a throttle nature. THis violent shut down is how my crank key was killed and the 181 pulley that was on it. The key was not too thick and sorta short for me, My new one is BIGGIE.
Woody, Be cool get a better cooler
Old Oct 27, 2008 | 06:26 AM
amg-jerry's Avatar
I personally checked your tune and your speed limter has been raised to well above 200 MPH.
I would check your IAT's and start there.
All speed limiters are raised with our tuning.
Old Oct 27, 2008 | 07:13 PM
It falls of smoothly, no jerking it's just as you have described, 2 seconds is what I told everyone then it kicked back on and I got back up to 152.
Since I was in the middle of noooowhere Texas, I did it all from a text message through my wife who posted for me.
Originally Posted by Montana Crossfire
I have to agree with SLK32 I have been visited by the dreaded speed limiter and it just feels like, there is no more. Gracefully stops your acceleration but never feels as though it is cutting out or anything which gives that sensation.
Mine cuts out at 3/4 of a mile @ 160mph but the timing system says at 158 or close to it on the speedo but it's really 152.9mph so I feel like I'm 6mph off at that speed. It's just as you have described, just an easy blaaaaaaahhhhhhhhhhhhhhh then it's back on again. I swear I told everyone all weekend, 2 seconds just went soft but at those speeds, 2 seconds is about 450 feet and there is only about 3 seconds to make up what I lost. It's just exactly what happened in March when I was told the limiter was still on the car, same feel, exact same location on the track and almost exact speed. If it's as you both described, this is exact, spot on in every way what happened. When I said limped back in the pits, it was my pride not the car, the car runs strong as ever.
Originally Posted by amg-jerry
I personally checked your tune and your speed limiter has been raised to well above 200 MPH.
The car sat for an hour before running with a low humidity and air temp outside of 74 degrees. It's 3 of us in the thread that all have the same feeling at the 155+ area with identical feelings of what the car does when the limiter turns on. There is no doubt in my mind after reading what has been posted that this is what it is. It's the same as in at the Texas Mile, same point on the track, same feel, sound and trap speed. I knew it and did it two more times on empty road on my way back home each time blllllaaaaaahhhhh then it would go again. It may be on the computer but I don't think it made it into the car.
Old Oct 27, 2008 | 07:30 PM
MD SRT6's Avatar
All I can say is sometimes loyalty is blinding! Just because you buy some software, it don't make you a tuner! I can gaurantee you I don't have a limiter Please do not ask how I know though.....
